Sensor update intervam from web interface
I’m using a Dallas sensor to measure the temperature in a room and want to get the sensor update interval value the ESPhome web interface.
The web interface looks like this:
For that I use the following code:
number:
    name: "Sensor update time (s)"
    optimistic: true
    mode: box
    min_value: '10'
    max_value: '300'
    step: '10'
    restore_value: yes
    initial_value: '30'
    on_value:
      then:
        - logger.log:
            format: "Chosen option: %s "
            args: ["x.c_str()"]
Next I want the use this value the set the sensor update_interval but I can find a way to use the value appended with ‘s’. Is there a way to get this done?
## Get the sensor data every <update_interval>
  - platform: dallas_temp
    address: 0xf8041662dbf3ff28
    accuracy_decimals: 1
    update_interval: 30s
    filters:
      - offset: 1.0
