I have temperature sensor sensor.online_thermometer_temperature, which holds temperature value from one of online services. History recorder for that sensor is enabled.
I want to create another sensor that would set its value based on average from (sensor.online_thermometer_temperature and sensor.online_thermometer_temperature value that was exactly 24 hours ago).
I need that value all day long so every time sensor.online_thermometer_temperature value changes or (in perfect solution) sensor.online_thermometer_temperature - 24h value changes i need updated average.
And here is my problem. I saw some examples based on SQL but nothing that i can use straightforward.
Is there any way to read that value from history other then SQL?
If SQL is the only way, how should i do it for MariaDB ?
Big thank you in advance for everybody willing to help.
Unfortunately if understand correctly Average Sensor for Home Assistant is not what i need.
I do not want to calculate average temperature for past 24h i need average form two distinct values now and now-24 hours, here is example:
I want to get temperature value for 7:00 AM today and average it with temperature that was at 7:00 AM yesterday.
Now i have sensor: (this is simplified version that not covers corner cases but works fine as example)
- sensor:
- name: "recommended_indoors_temperature"
unit_of_measurement: "°C"
state: "{{(states('sensor.online_thermometer_temperature')|float|round(0)) * 0.1 + 20}}"
and i want to replace sensor.online_thermometer_temperature with average from current sensor.online_thermometer_temperature value and value that was 24 hours ago. (to smooth sudden weather changes effect)
So in perfect solution I need that “template” listens for the following state changed events: sensor.online_thermometer_temperature and sensor.online_thermometer_temperature 24 hours ago value
But if i could listen to only sensor.online_thermometer_temperature changes for average update that still will be acceptable.
What is mandatory: every time sensor.online_thermometer_temperature value changes i have to average it with value from the same sensor 24 hours ago.
not sure if it helps, but if it is just about displaying the data you could use Apex Charts to display the curve for now to now-24h and on the same chart another curve for now-24h to now-48h.
So in essence you get two curves, one 1 for the last 24 hours and another parallel for the same 24hours on the day before.
See:
GitHub - RomRider/apexcharts-card: 📈 A Lovelace card to display advanced graphs and charts based on ApexChartsJS for Home Assistant).%20See%20statistics-,offset,-string
What I use when I need to store a certain value for an amount of time is to use the var extension from HACS.
here is an example:
ups_charger_last_power_consumption:
friendly_name: "UPS Charger Last Power Consumption"
force_update: false
restore: true
unit_of_measurement: "W"
value_template: "{{ float(states('sensor.ups_charger_power'),320) }}"
So every time I call the Service var.update with this Variable as entity it will execute the value_template and store this as value for the variable.
Hope this helps.
That still is not what i need, any other ideas?
Not really.
I’m no SQL ninja and I don’t use MariaDB, but I think the following might work to get the value 24hrs ago.
SELECT states.state FROM states
WHERE metadata_id=(
SELECT metadata_id FROM states_meta
WHERE entity_id='sensor.online_thermometer_temperature') and
last_updated_ts < UNIX_TIMESTAMP(NOW() - INTERVAL 24 HOUR)
ORDER BY last_updated_ts
DESC LIMIT 1
Then you can use a template sensor to get the average:
template:
- sensor:
- name: Online Therm Temp Average
state: >
{% set ents = ('sensor.online_thermometer_temperature',
'sensor.online_thermometer_temperature_24hr') | select('has_value') %}
{{ average(expand(ents)|map(attribute='state')|map('float')) }}
availability: >
{{ has_value('sensor.online_thermometer_temperature') or has_value('sensor.online_thermometer_temperature_24hr') }}
Hi. Finally i have solution that is described here: https://community.home-assistant.io/t/state-of-an-entity-sensor-x-time-ago/681370
