I’m wondering if there is a way to ‘template’ a sensor value. I’m not able to change the value that is published to mqtt, but I want to change the value that home assistant presents. Consider the following:
Perfect, I knew it had to be something like that. The only change I had to make was to take the quotes out from the values. They are presented as integers in the mqtt message.
I’ve tried to add an entry for the “sensor.weather_symbol:” under “customize:” in configuration.yaml but that did not work. After restart there were no visual effects.
