I can get these with an ApexChart (column) using a sensor for daily consumption… but I want to have a simple card (I wanted to use the “button-card”).
The problem is that I have a sensor for the daily value.
If I use a statistics card, I get the info, because the code is the following and using the offset (-1, -2, -3) I get the values.
- But the statistics card is not configurable… eg I can set the font size etc
type: statistic
entity: sensor.from_netz_daily
period:
calendar:
period: day
offset: -1
stat_type: change
I thought about the statistics platform… using the code below…
- but this allows me for yesterday and I have no way to get the values for the “day before yesterday” since if I specify 2 days I cant say it should return only the 2 days ago…
- platform: statistics
name: "From Netz 1 day ago"
entity_id: sensor.from_netz_daily
state_characteristic: value_max
max_age:
days: 1
Any help please?
