Home Assistant is great when it’s all working. When it isn’t, it’s a pain, and only then do you discover the things that have been in error for ages: a sensor unavailable since the spring, an integration that never came back after an update, a battery long flat.
Has anyone else looked at 30 Hue bulbs and 20 Shelly switches and decided not to bother with an automation for each one dropping out of range? Or built a dashboard panel for the things that need attention, knowing all the while that something was missed? Sensor Watch is for that.
It started as part of Casa Mia, and I mentioned it in that thread, but it’s now a standalone integration that anyone can install, with or without Casa Mia.
What it does
You tell it once what normal looks like, and it tells you only when something isn’t. Each watched sensor gets a level:
| Level | Means | Example |
| Nominal | All is well. | The softener’s salt is above 25%. |
| Task | Something to do, not a fault. | Top up the salt. |
| Warning | Worth a look. | The freezer is at −14 °C. |
| Error | Something is wrong. | The freezer is at −8 °C, or its sensor is unavailable. |
| Critical | Drop everything. | A leak sensor is wet. |
A sensor that goes unavailable counts as an error by default, once it has been gone for five minutes, because a sensor that has stopped reporting is often the first sign of a broken integration or a flat battery. It watches Home Assistant itself too: the Recorder, and every integration that fails to set up.
You don’t have to set up each sensor by hand:
- Groups cover the big classes of thing: every battery, every leak sensor, every Shelly plug’s voltage. Anything that matches later joins by itself, so the plug you add next month is watched without you remembering.
- A library of 86 profiles gives the bands, each saying where its numbers come from: mains voltage by country, batteries, broadband, pool and hot tub chemistry, freezers, heating and more.
- Scan my house looks at what you have and suggests groups, with bands taken from each sensor’s own history.
It isn’t a replacement for automations. Automations take action; Sensor Watch is the trigger that starts them. Each change of level fires an event, there are device triggers, summary sensors (Status, Tasks, Warnings, Errors, Critical) and a List action, and a Notify on Sensor Watch blueprint that sends your phone a notification in a few clicks.
It has its own page in Home Assistant’s sidebar for setting it up, a card that lists what needs attention (and shows nothing on a quiet day), a gauge card, and an eye in each watched entity’s dialog showing its level.
Getting it
It’s Beta: complete and used every day in our house, and its features have settled. Please tell me what breaks in yours.
It’s not in the HACS catalog or the Marketplace yet (the request is in), so you need to add the repo yourself:
- Add it to HACS with this button, or add
https://github.com/gazoodle/casa-mia-sensor-watchas a custom repository of the type Integration:
- Download it, then restart Home Assistant.
- In Settings → Devices & services, choose Add integration and pick Sensor Watch.
It needs Home Assistant 2026.3 or later. If you use Casa Mia as well, there’s nothing to do: the app takes over keeping it up to date, and your watches carry on.
- Repository: GitHub - gazoodle/casa-mia-sensor-watch: Tell it once what normal looks like, for every sensor in the house, and it tells you only when something isn't: what needs doing, or has gone wrong, before the family notices. · GitHub
- Docs: casa-mia/docs/applets/sensor-watch.md at cd152d50c46a0644c7b3a7bfde1869e1d827c1d2 · gazoodle/casa-mia · GitHub
- Issues: Issues · gazoodle/casa-mia · GitHub
