try:
{%- set degrees = states('sensor.winddirection')|float %}
{%- set path = '/local/weather/wind_compass/' %}
{%- set ext = '.png' %}
{%- set num = ((degrees // 11.25) * 11.25 // 1) | int %}
{%- set num = 0 if num == 360 else num %}
{{ "{}{}{}".format(path,num,ext) }}
and
wind_compass_abbreviation:
friendly_name: Windrichting Afkorting
value_template: >
{% set degrees = states('sensor.winddirection')|float %}
{% set abbr = ['N','NNNO','NNO','ONNO','NO','NONO','ONO','OONO',
'O','OOZO','OZO','ZOZO','ZO','OZZO','ZZO','ZZZO',
'Z','ZZZW','ZZW','ZZW','ZW','ZWZW','WZW','WWZW',
'W','WWNW','WNW','NWNW','NW','WNNW','NNW','NNNW' ] %}
{%- set i = ((degrees / 11.25) | round(0)) | int %}
{%- set i = 0 if i == 32 else i %}
{{ abbr[i] }}
Theo_Bijma
(Theo Bijma)
December 14, 2019, 1:43pm
22
Awesome! It works really well!
jugla
April 13, 2020, 4:26pm
23
Thanks a lot .
I have a netatmo wheather station.
I made the following code
sensors:
wind_angle:
friendly_name: "Wind angle"
unit_of_measurement: 'degrees'
value_template: "{{ states('sensor.netatmo_netatmo_sceaux_anemometre_balcon_angle') | regex_findall_index('([0-9]+)',index=0,ignorecase=TRUE) }}"
sensors:
wind_compass:
# friendly_name: Windrichting
# icon_template: mdi:compass
value_template: >
{{ states('sensor.wind_angle') }}
friendly_name_template: >
{% set degrees = states('sensor.wind_angle')|float %}
{% set abbr = ['N','NNNE','NNE','ENNE','NE','NENE','ENE','EENE','E','EESE','ESE','SESE','SE',
'ESSE','SSE','SSSE','S','SSSW','SSW','WSSW','SW','SWSW','WSW','WWSW','W','WWNW',
{{ abbr[i] }}
unit_of_measurement: '°'
entity_picture_template: >
{% set path = '/local/WindCompass/' %}
{% set ext = '.png' %}
{{path-}}
{%- if 354.38 <= degrees or degrees <= 5.62 -%} 0
{%- else -%}
{{ ( ((degrees/11.25)|round )*11.25 )| round}}
{%- endif -%}
{{-ext-}}
I 've used the above “png” files.
NB : the files have to be put at home_assistant/www/foobar path. It is seen as /local/foobar.
@jugla Maybe also add some attributes to your compass:
entity_picture_template: >-
{{path-}}
{%- else -%}
{%- endif -%}
{{-ext-}}
attribute_templates:
speed: "{{states('sensor.weather_wind_speed')}} {{state_attr('sensor.weather_wind_speed', 'unit_of_measurement')}}"
speed_txt: >-
{% set speed = states('sensor.weather_wind_speed')|float %}
{% if 0 <= speed <= 0.2 %} Stille
{% elif speed <= 1.5 %} Flau vind
{% elif speed <= 3.3 %} Svak vind
{% elif speed <= 5.4 %} Lett bris
{% elif speed <= 7.9 %} Laber bris
{% elif speed <= 10.7 %} Frisk bris
{% elif speed <= 13.8 %} Liten kuling
{% elif speed <= 17.1 %} Stiv kuling
{% elif speed <= 20.7 %} Sterk kuling
{% elif speed <= 24.4 %} Liten storm
{% elif speed <= 28.4 %} Full storm
{% elif speed <= 32.6 %} Sterk storm
{% elif speed > 32.7 %} Orkan
{% endif %}
jugla
April 13, 2020, 10:05pm
25
Thanks a lot, I will try.
Just a remark with the “round formula”
You must link(or copy) some xxx.png.
112 --> 113
123 --> 124
157 --> 158
168 --> 169
202 --> 203
213 --> 214
22 --> 23
247 --> 248
258 --> 259
292 --> 293
303 --> 304
337 --> 338
348 --> 349
33 --> 34
And to simplify the code, you can link 0 with 360.
Just wanted to add that I made a little Python script that generates wind direction icons that also incorporate some indication of the wind speed in whatever style you want (feel free to make them fancier) and I made a relatively simple template as well:
My template is relatively simple and uses rounding like this:
sensors:
wind_compass:
friendly_name: "Wind bearing"
value_template: >
{{ state_attr("weather.ksea_hourly", "wind_bearing") }}
unit_of_measurement: "°"
{% set path = '/local/wind/' %}
{{path-}}
{{((state_attr("weather.ksea_hourly", "wind_bearing") * 16 / 360)|round(0) *360/16) | int-}}_
{%- if state_attr("weather.ksea_hourly","wind_speed") <= 8 -%}L
{%- elif state_attr("weather.ksea_hourly","wind_speed") <= 15 -%}M
{%- else -%}H
{%-endif-%}
{{-ext-}}
Not too beautiful yet, but works!
tomvanswam
(Tom van Swam)
August 15, 2020, 12:18pm
27
Hi, I created a Lovelace Card that accepts an entity and displays a css build compass. No images required! Might be of use to some of you.
I made a lovelace compass card to point out the way the wind is blowing, the sun is at or where lightning is coming from.
[compass-card-inward]
Install it with HACS (search for compass) or check the readme in on github for manual installation if you don’t have HACS.
Love to hear your feedback.
Edit: updated screenshot to match v0.2.0
mimmoely
(Mimmoely)
April 24, 2021, 7:04am
28
Hi I have configured windcompass as per your advice and everything works fine but when the wind direction is O ° the image does not work correctly in the North direction
# WIND COMPASS #
sensors:
value_template: >-
{% if 354.38 <= states('sensor.openweathermap_wind_bearing')|float <= 5.62 %}
N
{% elif 5.63 <= states('sensor.openweathermap_wind_bearing')|float <= 16.87 %}
NbE
{% elif 16.88 <= states('sensor.openweathermap_wind_bearing')|float <= 28.12 %}
NNE
{% elif 28.13 <= states('sensor.openweathermap_wind_bearing')|float <= 39.37 %}
NEbN
{% elif 39.38 <= states('sensor.openweathermap_wind_bearing')|float <= 50.62 %}
NE
{% elif 50.63 <= states('sensor.openweathermap_wind_bearing')|float <= 61.87 %}
NEbE
{% elif 61.88 <= states('sensor.openweathermap_wind_bearing')|float <= 73.12 %}
ENE
{% elif 73.13 <= states('sensor.openweathermap_wind_bearing')|float <= 84.37 %}
EbN
{% elif 84.38 <= states('sensor.openweathermap_wind_bearing')|float <= 95.62 %}
E
{% elif 95.63 <= states('sensor.openweathermap_wind_bearing')|float <= 106.87 %}
EbS
{% elif 106.88 <= states('sensor.openweathermap_wind_bearing')|float <= 118.12 %}
ESE
{% elif 118.13 <= states('sensor.openweathermap_wind_bearing')|float <= 129.37 %}
SEbE
{% elif 129.38 <= states('sensor.openweathermap_wind_bearing')|float <= 140.62 %}
SE
{% elif 140.63 <= states('sensor.openweathermap_wind_bearing')|float <= 151.87 %}
SEbS
{% elif 151.88 <= states('sensor.openweathermap_wind_bearing')|float <= 163.12 %}
SSE
{% elif 163.13 <= states('sensor.openweathermap_wind_bearing')|float <= 174.37 %}
SbE
{% elif 174.38 <= states('sensor.openweathermap_wind_bearing')|float <= 185.62 %}
S
{% elif 185.63 <= states('sensor.openweathermap_wind_bearing')|float <= 196.87 %}
SbW
{% elif 196.88 <= states('sensor.openweathermap_wind_bearing')|float <= 208.12 %}
SSW
{% elif 208.13 <= states('sensor.openweathermap_wind_bearing')|float <= 219.37 %}
SWbS
{% elif 219.38 <= states('sensor.openweathermap_wind_bearing')|float <= 230.62 %}
SW
{% elif 230.63 <= states('sensor.openweathermap_wind_bearing')|float <= 241.87 %}
SWbW
{% elif 241.88 <= states('sensor.openweathermap_wind_bearing')|float <= 253.12 %}
WSW
{% elif 253.13 <= states('sensor.openweathermap_wind_bearing')|float <= 264.37 %}
WbS
{% elif 264.38 <= states('sensor.openweathermap_wind_bearing')|float <= 275.62 %}
W
{% elif 275.63 <= states('sensor.openweathermap_wind_bearing')|float <= 286.87 %}
WbN
{% elif 286.88 <= states('sensor.openweathermap_wind_bearing')|float <= 298.12 %}
WNW
{% elif 298.13 <= states('sensor.openweathermap_wind_bearing')|float <= 309.37 %}
NWbW
{% elif 309.38 <= states('sensor.openweathermap_wind_bearing')|float <= 320.62 %}
NW
{% elif 320.63 <= states('sensor.openweathermap_wind_bearing')|float <= 331.87 %}
NWbN
{% elif 331.88 <= states('sensor.openweathermap_wind_bearing')|float <= 343.12 %}
NNW
{% elif 343.13 <= states('sensor.openweathermap_wind_bearing')|float <= 354.37 %}
NbW
{% endif %}
#- platform: template
# sensors:
# wind_compass_point:
# value_template: >-
# {% if 354.38 <= states('sensor.openweathermap_wind_bearing')|float <= 5.62 %}
# North
# {% elif 5.63 <= states('sensor.openweathermap_wind_bearing')|float <= 16.87 %}
# North by east
# {% elif 16.88 <= states('sensor.openweathermap_wind_bearing')|float <= 28.12 %}
# North-northeast
# {% elif 28.13 <= states('sensor.openweathermap_wind_bearing')|float <= 39.37 %}
# Northeast by north
# {% elif 39.38 <= states('sensor.openweathermap_wind_bearing')|float <= 50.62 %}
# Northeast
# {% elif 50.63 <= states('sensor.openweathermap_wind_bearing')|float <= 61.87 %}
# Northeast by east
# {% elif 61.88 <= states('sensor.openweathermap_wind_bearing')|float <= 73.12 %}
# East-northeast
# {% elif 73.13 <= states('sensor.openweathermap_wind_bearing')|float <= 84.37 %}
# East by north
# {% elif 84.38 <= states('sensor.openweathermap_wind_bearing')|float <= 95.62 %}
# East
# {% elif 95.63 <= states('sensor.openweathermap_wind_bearing')|float <= 106.87 %}
# East by south
# {% elif 106.88 <= states('sensor.openweathermap_wind_bearing')|float <= 118.12 %}
# East-southeast
# {% elif 118.13 <= states('sensor.openweathermap_wind_bearing')|float <= 129.37 %}
# Southeast by east
# {% elif 129.38 <= states('sensor.openweathermap_wind_bearing')|float <= 140.62 %}
# Southeast
# {% elif 140.63 <= states('sensor.openweathermap_wind_bearing')|float <= 151.87 %}
# Southeast by south
# {% elif 151.88 <= states('sensor.openweathermap_wind_bearing')|float <= 163.12 %}
# South-southeast
# {% elif 163.13 <= states('sensor.openweathermap_wind_bearing')|float <= 174.37 %}
# South by east
# {% elif 174.38 <= states('sensor.openweathermap_wind_bearing')|float <= 185.62 %}
# South
# {% elif 185.63 <= states('sensor.openweathermap_wind_bearing')|float <= 196.87 %}
# South by west
# {% elif 196.88 <= states('sensor.openweathermap_wind_bearing')|float <= 208.12 %}
# South-southwest
# {% elif 208.13 <= states('sensor.openweathermap_wind_bearing')|float <= 219.37 %}
# Southwest by south
# {% elif 219.38 <= states('sensor.openweathermap_wind_bearing')|float <= 230.62 %}
# Southwest
# {% elif 230.63 <= states('sensor.openweathermap_wind_bearing')|float <= 241.87 %}
# Southwest by west
# {% elif 241.88 <= states('sensor.openweathermap_wind_bearing')|float <= 253.12 %}
# West-southwest
# {% elif 253.13 <= states('sensor.openweathermap_wind_bearing')|float <= 264.37 %}
# West by south
# {% elif 264.38 <= states('sensor.openweathermap_wind_bearing')|float <= 275.62 %}
# West
# {% elif 275.63 <= states('sensor.openweathermap_wind_bearing')|float <= 286.87 %}
# West by north
# {% elif 286.88 <= states('sensor.openweathermap_wind_bearing')|float <= 298.12 %}
# West-northwest
# {% elif 298.13 <= states('sensor.openweathermap_wind_bearing')|float <= 309.37 %}
# Northwest by west
# {% elif 309.38 <= states('sensor.openweathermap_wind_bearing')|float <= 320.62 %}
# Northwest
# {% elif 320.63 <= states('sensor.openweathermap_wind_bearing')|float <= 331.87 %}
# Northwest by north
# {% elif 331.88 <= states('sensor.openweathermap_wind_bearing')|float <= 343.12 %}
# North-northwest
# {% elif 343.13 <= states('sensor.openweathermap_wind_bearing')|float <= 354.37 %}
# North by west
# {% endif %}
# direzione in gradi con icona bussola
wind_compass:
friendly_name: "Wind direction"
value_template: '{{ states.sensor.openweathermap_wind_bearing.state }}'
friendly_name_template: "Wind direction - {{ states.sensor.wind_compass_point.state }}"
/local/weather/windcompass/N.png
/local/weather/windcompass/NbE.png
/local/weather/windcompass/NNE.png
/local/weather/windcompass/NEbE.png
/local/weather/windcompass/NE.png
/local/weather/windcompass/ENE.png
/local/weather/windcompass/EbN.png
/local/weather/windcompass/E.png
/local/weather/windcompass/EbS.png
/local/weather/windcompass/ESE.png
/local/weather/windcompass/SEbE.png
/local/weather/windcompass/SE.png
/local/weather/windcompass/SEbS.png
/local/weather/windcompass/SSE.png
/local/weather/windcompass/SbE.png
/local/weather/windcompass/S.png
/local/weather/windcompass/SbW.png
/local/weather/windcompass/SSW.png
/local/weather/windcompass/SWbS.png
/local/weather/windcompass/SW.png
/local/weather/windcompass/SWbW.png
/local/weather/windcompass/WSW.png
/local/weather/windcompass/WbS.png
/local/weather/windcompass/W.png
/local/weather/windcompass/WbN.png
/local/weather/windcompass/WNW.png
/local/weather/windcompass/NWbW.png
/local/weather/windcompass/NW.png
/local/weather/windcompass/NWbN.png
/local/weather/windcompass/NNW.png
/local/weather/windcompass/NbW.png
{% endif %}
small problem
You are right. Something has changes so this does not work anymore.
This should work:
{% set degrees = states('sensor.wind_compass')|float %}
{% if degrees <= 5.62 %} /local/WindCompass/0.png
{% elif degrees <= 16.87 %} /local/WindCompass/11.png
{% elif degrees <= 28.12 %} /local/WindCompass/22.png
{% elif degrees <= 39.37 %} /local/WindCompass/33.png
{% elif degrees <= 50.62 %} /local/WindCompass/45.png
{% elif degrees <= 61.87 %} /local/WindCompass/56.png
{% elif degrees <= 73.12 %} /local/WindCompass/67.png
{% elif degrees <= 84.37 %} /local/WindCompass/78.png
{% elif degrees <= 95.62 %} /local/WindCompass/90.png
{% elif degrees <= 106.87 %} /local/WindCompass/101.png
{% elif degrees <= 118.12 %} /local/WindCompass/112.png
{% elif degrees <= 129.37 %} /local/WindCompass/123.png
{% elif degrees <= 140.62 %} /local/WindCompass/135.png
{% elif degrees <= 151.87 %} /local/WindCompass/146.png
{% elif degrees <= 163.12 %} /local/WindCompass/157.png
{% elif degrees <= 174.37 %} /local/WindCompass/168.png
{% elif degrees <= 185.62 %} /local/WindCompass/180.png
{% elif degrees <= 196.87 %} /local/WindCompass/191.png
{% elif degrees <= 208.12 %} /local/WindCompass/202.png
{% elif degrees <= 219.37 %} /local/WindCompass/213.png
{% elif degrees <= 230.62 %} /local/WindCompass/225.png
{% elif degrees <= 241.87 %} /local/WindCompass/236.png
{% elif degrees <= 253.12 %} /local/WindCompass/247.png
{% elif degrees <= 264.37 %} /local/WindCompass/258.png
{% elif degrees <= 275.62 %} /local/WindCompass/270.png
{% elif degrees <= 286.87 %} /local/WindCompass/281.png
{% elif degrees <= 298.12 %} /local/WindCompass/292.png
{% elif degrees <= 309.37 %} /local/WindCompass/303.png
{% elif degrees <= 320.62 %} /local/WindCompass/315.png
{% elif degrees <= 331.87 %} /local/WindCompass/326.png
{% elif degrees <= 343.12 %} /local/WindCompass/337.png
{% elif degrees <= 354.37 %} /local/WindCompass/348.png
{% else %} /local/WindCompass/0.png
{% endif %}
mimmoely
(Mimmoely)
April 25, 2021, 8:50pm
30
it works! @Tomahawk Thank you very much
