Sensor with different values in an apexchart pie -- MelCloud -- OperationMode example
Hello
I was searching the way to display a pie chart from an uniq Sensor with different values. Apexchart pie uses different entities to construct the pie
This is an example with MelCloud Operation mode
The idea is to provide a pie chart with Operation Mode day distribution
OperationMode
Important Notes:
Restart Hassio completely after sensors integration. It’s mandatory to restart always than a new integration is included.
Accuracy of pie chart depends on update interval of Rest Api integration. It’s not recomended to set a very low interval becuase it will collapse the Cloud integration
The configuration is the following one
configuration.yaml
Configuration for REST Api
sensor REST API Melcloud
  - platform: rest
    resource: !secret mcloud_resource
    method: GET
    headers:
        X-MitsContextKey: !secret mcloud_api_key
    value_template: '{{value_json[0].Structure.Devices[0]["Device"]["LastTimeStamp"]}}'
    icon: mdi:heat-wave
    scan_interval: 300
    json_attributes_path: !secret mcloud_att_path
    json_attributes:
      - OperationMode
      - LastTimeStamp
Configuration of Sensors
Operation Mode Sensor with names (inside configuration.yaml):
    sensors:
      heat_pump_operationmode:
        friendly_name: "Heat Pump Operation Mode"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',0) %}
            Off
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',1) %}
            Heating ACS
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',2) %}
            Heating Radiators
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',3) %}
            Cooling
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',4) %}
            Standby
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',5) %}
            Defrost
          {% elif is_state_attr('sensor.heat_pump_api','OperationMode',6) %}
            Legionella
          {% else %}
            Unknown
          {% endif %}
Sensor for each of the Operation mode. These sensors will be used to check that operation mode is correctly working ( configure inside plaftorm template in configuration.yaml file)
“Off mode” has been change from 0 to 10, to be sure it correctly detected
      heat_pump_opm_off:
        friendly_name: "Heat Pump OPM OFF"
        value_template: >-
            {{ 10.0 }}
          {% else %}
            {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_acs:
        friendly_name: "Heat Pump OPM ACS"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',1) %}
            {{ 1.0 }}
          {% else %}
            {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_heatr:
        friendly_name: "Heat Pump OPM HeatR"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',2) %}
             {{ 2.0 }}
          {% else %}
             {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_cool:
        friendly_name: "Heat Pump OPM Cool"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',3) %}
            {{ 3.0 }}
          {% else %}
             {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_standby:
        friendly_name: "Heat Pump OPM Standby"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',4) %}
            {{ 4.0 }}
          {% else %}
             {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_defrost:
        friendly_name: "Heat Pump OPM Defrost"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',5) %}
            {{ 5.0 }}
          {% else %}
            {{ none }}
          {% endif %}
        device_class: aqi
      heat_pump_opm_legionella:
        friendly_name: "Heat Pump OPM Legg"
        value_template: >-
          {% if is_state_attr('sensor.heat_pump_api','OperationMode',6) %}
            {{ 6.0 }}
          {% else %}
             {{ none }}
          {% endif %}
        device_class: aqi
Configuration of history_stat sensors for each operation Mode. These will control the time used by each sensor ( configure at the same level of platform template )
  - platform: history_stats
    entity_id: sensor.heat_pump_operationmode
    state: "Heating Radiators"
    type: time
    start: "{{ now().replace(hour=0, minute=0, second=0) }}"
    end: "{{ now() }}"
    #duration:
    #  hours: 24
    state: "Off"
    type: time
    end: "{{ now() }}"
    state: "Heating ACS"
    type: time
    end: "{{ now() }}"
    state: "Cooling"
    type: time
    end: "{{ now() }}"
    state: "Standby"
    type: time
    end: "{{ now() }}"
    state: "Defrost"
    type: time
    end: "{{ now() }}"
    state: "Legionella"
    type: time
    end: "{{ now() }}"
Display of sensors. Add new history graph card in frontend Hass
type: history-graph
hours_to_show: 24
entities:
  - entity: sensor.heat_pump_opm_acs
  - entity: sensor.heat_pump_opm_defrost
  - entity: sensor.heat_pump_opm_heatr
  - entity: sensor.heat_pump_opm_off
  - entity: sensor.heat_pump_opm_standby
  - entity: sensor.heat_pump_opm_legionella
  - entity: sensor.heat_pump_opm_cool
  - entity: sensor.heat_pump_operationmode
  - entity: sensor.heat_pump_opm_heatr_time
  - entity: sensor.heat_pump_opm_off_time
  - entity: sensor.heat_pump_opm_acs_time
  - entity: sensor.heat_pump_opm_cooling_time
  - entity: sensor.heat_pump_opm_defrost_time
  - entity: sensor.heat_pump_opm_stand_time
  - entity: sensor.heat_pump_opm_legion_time
update_interval: 60m
Configuration of Pie Chart
Add new apexchart Card for previous day
type: custom:apexcharts-card
chart_type: pie
graph_span: 24h
span:
  start: day
header:
  show: true
  floating: false
  title: Ecodan Usage Yesterday
  show_states: false
  colorize_states: true
show:
  last_updated: true
all_series_config:
  offset: '-1d'
  group_by:
    func: max
    duration: 24h
  show:
    datalabels: percent
series:
    color: '#949391'
    color: '#f2ac1f'
    color: '#cfcf15'
    color: '#b31212'
    color: cyan
    color: '#abcf37'
    color: '#56a5ec'
Same configuration for actual day ( only difference remove offset: ‘-1d’ from previous)
chart_type: pie
graph_span: 24h
span:
  start: day
header:
  show: true
  floating: false
  title: Ecodan Usage
  show_states: false
show:
  last_updated: true
all_series_config:
  group_by:
    func: max
    duration: 24h
  show:
    datalabels: percent
series:
    color: '#949391'
    color: '#f2ac1f'
    color: '#cfcf15'
    color: '#b31212'
    color: cyan
    color: '#abcf37'
    color: '#56a5ec'
The result could be check with MelCloudApp.
Take into account that values are not exactly the same. Perhaps the update ratio from MelCloud App is different or have another implementation.
Then a message with the summary could be sent to telegram. I only could send in text mode
alias: Send Ecodan Distribution
  - platform: time
    at:
      - "23:59:50"
condition: []
  - service: notify.NOTIFIER_NAME
      title: Ecodan Energy Distribution
      message: >-
        {% set total = (states("sensor.heat_pump_opm_heatr_time")|float +
              states("sensor.heat_pump_opm_off_time")|float  +
              states("sensor.heat_pump_opm_acs_time")|float  +
              states("sensor.heat_pump_opm_cooling_time")|float  +
              states("sensor.heat_pump_opm_defrost_time")|float  +
              states("sensor.heat_pump_opm_stand_time")|float  +
              states("sensor.heat_pump_opm_legion_time")|float)|round(2) %}
          📉<b>Total:</b> {{ total }}h📈
        ⛔️ Off:     {{ states("sensor.heat_pump_opm_off_time") }}h / {{
        ((states("sensor.heat_pump_opm_off_time")|float / total ) *
        "100.0"|float)| round(2) }} %
        🚰 ACS:    {{ states("sensor.heat_pump_opm_acs_time") }}h / {{
        ((states("sensor.heat_pump_opm_acs_time")|float / total ) *
        ♨️ Heat:   {{ states("sensor.heat_pump_opm_heatr_time") }}h / {{
        ((states("sensor.heat_pump_opm_heatr_time")|float / total ) *
        ❄️ Cool:   {{ states("sensor.heat_pump_opm_cooling_time") }}h / {{
        ((states("sensor.heat_pump_opm_cooling_time")|float / total ) *
        ☢️ Defrost: {{ states("sensor.heat_pump_opm_defrost_time") }}h / {{
        ((states("sensor.heat_pump_opm_defrost_time")|float / total ) *
        ♻️ Standby: {{ states("sensor.heat_pump_opm_stand_time") }}h / {{
        ((states("sensor.heat_pump_opm_stand_time")|float / total ) *
        ⚕️ Legionella: {{ states("sensor.heat_pump_opm_legion_time") }}h / {{
        ((states("sensor.heat_pump_opm_legion_time")|float / total ) *
        parse_mode: html
        disable_notification: true
I hope this helps or could be used as base for other sensors.
Best regards
