Hi, I read/write data from/to a modbus.
I can publish a value via MQTT in integers 0-4 but when I read the value it is in text: "Normal, Hastighet 1, Hastighet 2, Hastighet 3, Hastighet 4)
I have a slider in lovelace that I try to update based on this information. I guess this should be easy but not for me
Now I have the automation set as this, and this would work it the data it reads was in integers the same way as I write but now I guess I should convert it someway
alias: 'From Nibe: Set Fan Speed Slider'
description: ''
- platform: state
entity_id:
- sensor.nibe_fan_mode
condition: []
- service: input_number.set_value
value: '{{ states(''sensor.nibe_fan_mode'') }}'
entity_id: input_number.nibe_fan_mode
mode: single
tom_l
May 22, 2022, 9:00am
2
What does this display in the template editor?
{{ states('sensor.nibe_fan_mode') }}
Hi, attached picture. It shows “Hastighet 2” now
So I’d like to do something like
If sensor.nibe.fan_mode = 'Hastighet 2' then
input.number.nibe_fan_mode:=2;
but not sure how to do that in HA as it is not my native language
Hellis81
(Hellis81)
May 24, 2022, 5:55am
5
This should probably work if it always says "Hastighet " before the integer.
description: ''
- platform: state
entity_id:
condition: []
value: '{{ states(''sensor.nibe_fan_mode'') | replace("Hastighet ", "") | int }}'
mode: single
Thanks for the reply Hellis81,
it did not seem to work straight away but feels like it should be close
this is now my code:
description: ''
- platform: state
entity_id:
condition: []
mode: single
but as I set the fan to “Hastighet 3” from the unit it did call the automation but did not update the slider.
tom_l
May 24, 2022, 6:46am
7
Or if it is always a single digit at the end, you could use Python’s slice:
value: '{{ states(''sensor.nibe_fan_mode'') [-1:] }}'
This [-1:] selects the last character of the string.
Thank you Tom, I tried with this one also but I had no luck. I am a noob so there might be something silly I am missing.
This is the code now:
description: ''
- platform: state
entity_id:
condition: []
mode: single
In the developer tools it showed nicely
but despite running the actions it does not update the slider
(P.S. The Value can also be “Normal” then the slider should be at 0)
tom_l
May 24, 2022, 7:01am
9
It might be something that the template editor does not support. Not sure Don’t use it.
It should work in YAML mode if it works in the template editor.
I might have a really silly misstake… The Helper slider is named NibeFan, not Nibe_fan_mode…Thanks for all the help!
Edit: Yes, it was just me having the wrong name on the helper… Thank you and sorry for my confusion!
Hellis81
(Hellis81)
May 24, 2022, 7:08am
11
In that case you probably need something like:
description: ''
- platform: state
entity_id:
condition: []
value: '{{ states(''sensor.nibe_fan_mode'') | replace("Hastighet", "") | replace("Normal", "0") | trim | int }}'
entity_id: input_number.nibefan # make sure this is correct
mode: single
Thank you this works perfectly
