Hey guys,
For some reason my fibaro motion sensors changed name after upgrading. They went from:
fibaro_system_fgms001_motion_sensor_luminance_2 to
fibaro_system_fgms001_motion_sensor_luminance_2_3
which was weird by itself, but I took this as an opportunity to clean some code. So, I decided to use customise to get some friendly names in the future. Now for some reason my sensors are no longer working. I have some data_templates with the following code:
living_brightness:
friendly_name: ‘Living Brightness Level’
value_template: >-
{%- if is_state(‘input_boolean.nightmode’, ‘on’ ) %}
20
{% elif states.sensor.fibaro_system_fgms001_motion_sensor_luminance_2_3.state | float == 455.0 %}
50
{% elif states.sensor.fibaro_system_fgms001_motion_sensor_luminance_2_3.state | float > 400.0 %}
50
{% elif states.sensor.fibaro_system_fgms001_motion_sensor_luminance_2_3.state | float > 200.0 %}
100
{% elif states.sensor.fibaro_system_fgms001_motion_sensor_luminance_2_3.state | float < 200.0 %}
180
{% else %}
180
{%- endif %}
but after customising the sensors (e.g. sensor.fibaro_system_fgms001_motion_sensor_burglar_2_10 to living_burglar) the script no longer works. Checking the state in the development tool gives no numbers whatever I try (e.g. states.sensor.living_motion.state or states.living_motion.state, etc).
Can anyone shed a light on what’s going on?
Help is much appreciated.
Thanks!
