How can i modify y specify a sensor so that it shown under history as line graph? Currently it shown as:
Especially the Amps and the Volts graphs are not really helpful. Al line graph whould serve much better, like this one:
Your sensors need a unit_of_measurement to be displayed as a line graph.
After you add the unit to your sensors it will take a day to purge the data from the old bar type chart.
Yep. Give it a day and the bar chart will disappear (the chart only displays the last 24hrs).
For other readers: In configuration.yaml under sensor: i added βunit_of_measurement:β as follows:
- name: "INV1 - Solar/Battery Watts"
state_topic: "inverter/solar_battery_watts"
unit_of_measurement: "Watt"
β¦and than restarted/reloaded YAML
Use the </> formatting button, not the quote button.
Thanks Tom, now fixed.
