Sensors not adding into custom component - entity unknown.unknown=unknown
I’ve been working on a custom component for a while and have the main structure, etc, however additional sensors aren’t adding in, I’ve added logging to check that the sensor loop in async_setup_entry is being called correctly and it is, but when it comes to the returned value (that is then passed to async_add_entities) it’s empty and in the logs I get:
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] About to add sensors: [<entity unknown.unknown=unknown>, <entity unknown.
unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unkno
wn.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>]
Which is the number of sensors I’m trying to create but as you can see the entities are all unknown.
The sensor.py contains the following:
from __future__ import annotations
import logging
from homeassistant.components.sensor import (
    SensorDeviceClass,
    SensorEntity,
    SensorEntityDescription,
    SensorStateClass,
from homeassistant.config_entries import ConfigEntry
from homeassistant.const import PERCENTAGE,UnitOfLength,UnitOfTime
from homeassistant.core import HomeAssistant, callback
from homeassistant.helpers.device_registry import DeviceInfo
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.entity import EntityCategory
from homeassistant.helpers.update_coordinator import CoordinatorEntity
from .const import DOMAIN, MANUFACTURER
from .coordinator import HusqvarnaAutomowerBleEntity, HusqvarnaCoordinator
_LOGGER = logging.getLogger(__name__)
MOWER_SENSORS = [
        "name": "Battery Level",
        "query_key": "battery_level",
        "unit": PERCENTAGE,
        "device_class": SensorDeviceClass.BATTERY,
        "state_class": None,
        "sensor_class": SensorStateClass.MEASUREMENT,
        "entity_category": None,
        "sensor_icon": "mdi:battery",
        "description": "Mower battery level",
        "name": "Next Start Time",
        "query_key": "next_start_time",
        "unit": None,
        "device_class": None,
        "sensor_class": None,
        "sensor_icon": "mdi:timer",
        "description": "Mower next start time",
        "name": "Total running time",
        "query_key": "statistics[totalRunningTime]",
        "unit": UnitOfTime.SECONDS,
        "device_class": SensorDeviceClass.DURATION,
        "state_class": SensorStateClass.TOTAL,
        "entity_category": EntityCategory.DIAGNOSTIC,
        "description": "Mowers total running time",
        "name": "Total cutting time",
        "query_key": "totalCuttingTime",
        "description": "Mowers total cutting time",
        "name": "Total charging time",
        "query_key": "totalChargingTime",
        "description": "Mowers total charging time",
        "name": "Total searcing time",
        "query_key": "totalSearchingTime",
        "description": "Mowers total searing for base time",
        "name": "Total number of collisions",
        "query_key": "numberOfCollisions",
        "unit": None,
        "sensor_icon": "mdi:crash",
        "description": "Mowers number of collisions",
        "name": "Total number of charging cycles",
        "query_key": "numberOfChargingCycles",
        "unit": None,
        "sensor_icon": "mdi:charge",
        "description": "Mowers total number of charge cycles",
        "name": "Total cutting blade usage",
        "sensor_icon": "mdi:blade",
        "description": "Mowers total blade usage time",
async def async_setup_entry(
    hass: HomeAssistant,
    config_entry: ConfigEntry,
    async_add_entities: AddEntitiesCallback,
) -> None:
    """Set up AutomowerLawnMower sensor from a config entry."""
    coordinator: HusqvarnaCoordinator = hass.data[DOMAIN][config_entry.entry_id]
    _LOGGER.debug("Creating mower sensors")
    sensors = [AutomowerSensorEntity(coordinator, sensor_config) for sensor_config in MOWER_SENSORS]
    _LOGGER.debug("About to add sensors: " + str(sensors))
    if not sensors:
        _LOGGER.error("No sensors were created. Check SENSOR_CONFIG.")
    async_add_entities(sensors)
class AutomowerSensorEntity(CoordinatorEntity, SensorEntity):
    def __init__(self,coordinator: HusqvarnaCoordinator,config) -> None:
        """Set up AutomowerSensors."""
        super().__init__(coordinator)
        self._name = config["name"]
        self._query_key = config["query_key"]
        self._unit_of_measurement = config["unit"]
        self._device_class = config["device_class"]
        self._state = config["state_class"]
        self._sensor_class = config["sensor_class"]
        self._entity_category = config["entity_category"]
        self._description = config["description"]
        self._attributes = {"description": self._description}
        _LOGGER.debug("in AutomowerSensorEntity creating entity for: " + str(self._name))
#        super().__init__(coordinator)
#        self._update_attr()
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def state(self):
        """Return the state of the sensor."""
        data = self.coordinator.data
        if data:
            _LOGGER.debug("state of sensor data structure: " + str(data))
            value = data.get(self._query_key)
            if value:
                _LOGGER.debug("value of sensor data structure: " + str(value))
                return value
        return None
    @property
    def unit_of_measurement(self):
        """Return the unit of measurement of this sensor."""
        return self._unit_of_measurement
    @property
    def device_class(self):
        """Return the device class of this sensor."""
        return self._device_class
    @property
    def sensor_class(self):
        """Return the sensor class of this sensor."""
        return self._sensor_class
    @property
    def extra_state_attributes(self):
        """Return the state attributes."""
        return self._attributes
    @property
    def entity_category(self):
        """Return the entity category of this sensor."""
        return self._entity_category
    @callback
    def _handle_coordinator_update(self) -> None:
        """Handle coordinator update."""
        self._update_attr()
        super()._handle_coordinator_update()
    @callback
    def _update_attr(self) -> None:
        """Update attributes for sensor."""
        self._attr_native_value = None
        try:
            self._attr_native_value = self.coordinator.data[self._query_key]
            self._attr_available = self._attr_native_value is not None
            _LOGGER.debug("Update sensor %s with value %s", self._query_key, self._attr_native_value)
            return self._attr_native_value
        except KeyError:
            _LOGGER.error(
                "%s not a valid attribute",
                self._query_key,
    async def async_update(self):
        try:
        except KeyError:
            _LOGGER.error(
                self._query_key,
The code is executing, as my logs show:
2024-07-11 08:39:48.706 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] Creating mower sensors
2024-07-11 08:39:48.706 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Battery Level
2024-07-11 08:39:48.706 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Next Start Time
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total running time
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total cutting time
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total charging time
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total searcing time
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total number of collisions
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total number of charging cycles
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] in AutomowerSensorEntity creating entity for: Total cutting blade usage
2024-07-11 08:39:48.707 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] About to add sensors: [<entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>, <entity unknown.unknown=unknown>]
2024-07-11 08:39:48.708 DEBUG (MainThread) [custom_components.husqvarna_automower_ble.sensor] state of sensor data structure: {'battery_level': 100, 'activity': <MowerActivity.PARKED: 5>, 'state': <MowerState.RESTRICTED: 7>, 'next_start_time': datetime.datetime(2024, 7, 11, 12, 0, tzinfo=datetime.timezone.utc), 'statistics': {'totalRunningTime': 2646768, 'totalCuttingTime': 2511938, 'totalChargingTime': 812706, 'totalSearchingTime': 121312, 'numberOfCollisions': 12667, 'numberOfChargingCycles': 313, 'cuttingBladeUsageTime': 2511938}, 'operatorstate': 0}
So it seems to be the issue with the return data from my custom sensor AutomowerSensorEntity returning empty.
Any pointers please?
Just a quick glance at your code, im wondering if it is because you are not setting a unique id.
Thanks Mark.
I literally just came to the same conclusion too!
Adding:
self.attr_unique_id = f"{mower_id}{description.key}"
to the class has made it add.
Thank you so much!
