Sensors not getting added from Tellstick
I have a Telldus Duo connected to my Raspberry PI with HA.
It all works when it comes to the switches that I add in the Telldus-config and if I run a service call:
hassio.addon_stdin with:
{“addon”:“core_tellstick”,“input”:{“function”:“list-sensors”}}
I get response with all the sensors (only some listed below):
type=sensor protocol=fineoffset model=temperature id=115 temperature=-204.7 time=2019-05-15 06:39:40 age=89172
type=sensor protocol=fineoffset model=temperature id=42 temperature=-102.3 time=2019-05-13 19:45:02 age=214850
type=sensor protocol=fineoffset model=temperature id=178 temperature=-204.7 time=2019-05-15 09:19:41 age=79571
The problem is that they are not added so that I can use them in HA. I can not see them in dev-state or in unused-entities.
Can anyone understand why I get this problem?
In the yaml config I have the following:
  • platform: tellstick
    only_named:
    • id: 196
Anyone alive here? I suddenly got the exact same problem. I can see my sensors reporting in the tellstick log but the entities aren’t created. I Didn’t change a thing to make this fail. Not anything related to tellstick anyway.
