Hello, I am having some issues with HASSIO install on Pi.
It was working fine for last 2 months but started having issues.
Some of the issues are as follows,
(1) Aqara motion / Door / Temperature sensors are reporting intermittently. When I check ‘Xiaomi Home’ app I can all of the sensors are regularly updating but hassio don’t get the update.
(2) Kasa Tp-Link switches have become orphaned enities even though they are live and I can use native app to interact with them.
I am actually using ’ Home Assistant 0.118.4’ sorry for confusion.
i will reach out to Tp-Link to rollback.
Sorry i just checked and i can confirm i am still on old firmware i.e. 1.5.8 (UK). Do you think I will be impacted by something else.
I am using ’ Xiaomi Gateway (Aqara)’ to communicate to Aqara devices. This was perfectly working fine but broke for some reasons.
hi, i just tried deleting home-assistant_v2. db file as well but to no avail.
please see screenshots of the sensor. Xiaomi home is reporting motion but homeassistant does not.
I assume all the TP-Link devices and the Xiaomi Gateway communicate with Home Assistant via Wi-Fi.
If you can control the TP-Link devices with the Kasa app and you can see sensor updates in the Xiaomi app, that means your phone is communicating with them via Wi-Fi. It implies the switches and gateway are connected to Wi-Fi and are functioning normally.
We know Home Assistant is connected to Wi-Fi because you’re accessing it via your phone.
The missing link is the connection between Home Assistant and the switches and gateway.
Have you checked Home Assistant’s Log for error messages?
yes exactly this i was thinking all devices are communicating to internet,
but i dont have anything in logs which suggests these issues. Please see the following.
Till last night i was able to get battery states from sensors and also was able to turn on / off gateway light, today this has all stopped.
I was able to work KASA by removing the integration and adding it back, not sure if I do same to Aqara gateway i have to redo all device / entity names etc
