Sensors of Kraken integration with unavailable state
Hello ,
The kraken integration has been installed as per … Kraken - Home Assistant ( over core 2021.7 version )
There is no error in the Core Log
https://www.home-assistant.io/integrations/kraken
However all the created sensors are at unavailable state as per the attached screenshot
Is it a known issue ou just me ?
Please advise .
Thank you
I am seeing the same issue. It seems that they work well for a while, but then they all become unavailable. The only way I’m able to get them back is to delete the old sensors and create new ones.
Has anyone found a lasting solution?
After deletion and re-installing the Kraken integration , 4 sensors are working ( ask,bid,low_today , high_today )
All the 12 others sensors are marked “unavailable”
