Senz wifi: unable to track consumption?
I have 2 floor heaters raychem senz (works with the senz wifi integration)
Works perfectly in HA as a thermostat. But if I open the senz wifi app i can also see consumtion hour for hour. This would be great to show in the energy panel of HA as floor heating is a large consumer of electricity. Is it possible?
Hi
Im looking for the same. Did you come to any conclusion?
I have an idea. But that is all
I am quite certain that my 3 floor heaters consume the same amount of wqtt when turned on. And since home assistant can see the state of the heating ”heating” or ”idle” i think i can assume when it is heating it is deawing x kW and when idle it is drawing close to 0 kW. I wonder if I can configure Home Assistant to add this to energy dashboard.
Any idea @ErikJCD @milanmeu ?
@ErikJCD actually i got something to work.
I found a plugin called powercalc that could create a virtual power consumption item based on another item such as the floor heater.
Seem to work so-so. Tried to meassurr each floor heaters power and set it up. But total power consumption for 3 floor heaters is more than my total consumption in the house so I need to tweak it more.
I measured the heaters using my power meter connection. I turned them off and then on and checked the difference.
Hi, I want this as well. @deadlock did you find a solution?
Yes powercalc seem to work fairly well
You use “sub-profiles” to read the HVAC state for power calc or how do you do? :slight_smile:
Do you mind sharing the configuration for powercalc?
What states and/or condition did you use for the “On” state?
I’m also interested in the PowerCalc profiles for Senz.
Have anyone tried to import statistics from the Senz app into HA?
