Separate switches from dimmer in device
Is there a way to separate switches from dimmers in a device? For example on my insteon switches could I separate and create 3 entities (up button, down button, and dimmer) This would simplify using the switch for things other than the light itself, like using the up button to cycle through scenes, even when the light it on at 100%. Also wondering if I could do that with my Kasa dimmers (they only have one button) Or if there is another dimmer on the market that would do that.
I am using a workaround right now that is kinda clunky. In all my scenes, I only turn the lights on to 99% so it can still be “turned on” again to trigger the next scene, and off to 1% so it can still be “turned off”.
