Sequence of harmony hub commands not working as expected!
So I’ve got the harmony hub successfully sending commands and running activities. Where I’m running into an issue with with a script that involves multiple harmony hubs commands being send a couple of seconds apart.
The following commands in the sequence work (although with really big delays between the different commands):
Menu, DirectionDown, DirectionDown, DirectionDown
Then it fails at the next one: Select
I’m positive I’m using the correct device ID and command, see from my harmony hub conf file:
Device Commands
  39925136 - Panasonic TV
    PowerOff
    PowerOn
    PowerToggle
    Hyphen
    Number0
    Number1
    Number2
    Number3
    Number4
    Number5
    Number6
    Number7
    Number8
    Number9
    Mute
    VolumeDown
    VolumeUp
    PrevChannel
    ChannelDown
    ChannelUp
    DirectionDown
    DirectionLeft
    DirectionRight
    DirectionUp
    Select
    Stop
    Play
    Rewind
    Pause
    FastForward
    SkipBackward
    SkipForward
    Return
    Menu
    Favorite
    Green
    Red
    Blue
    Yellow
    Info
    Exit
    Aspect
    CC
    Input
    InputComponent1
    InputComponent2
    InputHdmi1
    InputHdmi2
    InputHDMI3
    InputPc
    InputTuner
    InputVideo1
    InputVideo2
    InputVideo3
    InputVideo4
    SAP
    SdCard
    SubMenu
    VieraLink
    VieraTools
here is the script:
bedtime:
  alias: 'Initiate bedtime mode'
  sequence:
    - service: scene.turn_on
      entity_id: scene.all_lights_off
    - service: tts.google_say
      entity_id: media_player.all_devices_group
        message: "Shutting everything down and turning the TV on. Good night"
    - service: remote.send_command
      data_template:
        entity_id: remote.harmony_hub
        command: PowerOn
        device: >
          39925136
    - service: media_player.media_stop
    - delay: 00:00:15
      data_template:
        command: Menu
        device: 39925136
      data_template:
        command: DirectionDown
        device: 39925136
      data_template:
        device: 39925136
      data_template:
        device: 39925136
      data_template:
        command: Select
        device: 39925136
      data_template:
        command: Select
        device: 39925136
      data_template:
        command: DirectionLeft
        device: 39925136
      data_template:
        command: Exit
        device: 39925136
The point of this is to have my sleep timer set on my TV automatically. It should go Menu, Down, Down, Down, Select, Select, Left, Exit but it getting suck at the SELECT command. Is that particular command just bugged for my Panasonic TV? If it isn’t fixable does anyone know of an alternate way for me to accomplish this with HA?
Would’ve thought it would be much simpler to do it the other way around, try setting it up as an activity on your Harmony and then either trigger the activity via HA as part of a script along with your lights or set the script up in emulated_hue and just add it to the activity on your Harmony and trigger it however you fancy.
True, I’ll probably just do that then. I try to avoid making activities since I have a lot already and they clutter things up but that is probably easiest. I haven’t tried emulated hue yet will set that up soon. Thank you.
I read somewhere that you could control the delay and repeats of a harmony command. Any idea where and how I adjust that in HA?
