I’m not finding much on the run_sequence
feature of appdaemon. I have several similar scripts where only, say, the volume is different. Right now, I have a portion of the yaml input repeated several times with an input_number
set to the volume I want.
Is there a way, using a run_sequence
, where I can pass it the name of the input_number
and the sequencer gets that state and uses that value? Thoughts?
The sequence script would look something like this, where an input_number
contains the volume level:
sequence:
name: Set volume on Sonos
steps:
- media_player/volume_set:
entity_id: media_player.living_room
value: 'input_number.set_living_room_volume'
The alternative is to write my own run_sequence
in Python and fill in the values, but that seems like overkill. I’m not sure I’d save any steps.
