I’m trying to create a read/write communication with an oldschool ventilation unit (Vallox) that uses RS-485 to communicate with control panels. I would like to use my HASS as a additional “control panel”. I have 2 USB-adapters and I have succesfully created a communication link between my PC and Rasp running the vanilla image of Home Assistant that you can download from the site.
Right now I am able to send messages from my PC. For example this would be temperature of the air supply:
01 11 20 5B 93 20
Last byte is the actual reading, one before that is the address and others are constant. I have this configuration now:
- platform: serial
serial_port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
baudrate: 9600
sensors:
vallox_tuloilma:
friendly_name: Vallox Tuloilma
unit_of_measurement: "°C"
value_template: "{{ states('sensor.serial_sensor').split(' ')[5] | float }}"
It does work like I planned but now I would like to make it a bit more sophisticated without learning python or anything like that because I would like to keep this quite simple and use out of box features. So the thing I need help in is creating a set of conditions with templates so that I would only read messages beginning with 01 11 20 5B and then I could set few addresses that I am interested in?
Another thing is writing to serial bus for fan speed commands. Is it possible without installing complex addons?
Thanks in advance
Still working on this one. My first message was a bit optimistic as I didn’t have the actual USB stick with serial communication attached to my Raspberry Pi. Now it is and I am able to receive the communications with SSH. It looks like this:
~ $ cat /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
!!!q!q +] ,^ 5!5h!5
2 3 *-!!!)\!)k!5h!5!!!q!q^C)\!)k!5h!5!!!q!q +] ,^ 5
Doesn’t make much sense like that. But when I convert it to hex with byteswap it starts to make sense to me:
~ $ hexdump -C /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
00000000 01 11 20 2b 00 5d 01 11 20 2c 00 5e 01 11 20 35 |.. +.].. ,.^.. 5|
00000010 a6 0d 01 11 20 34 a7 0d 01 11 20 32 a3 07 01 11 |.... 4.... 2....|
00000020 20 33 a9 0e 01 11 20 2a 2d 89 01 21 11 00 a3 d6 | 3.... *-..!....|
00000030 01 11 21 a3 01 d7 01 21 11 00 29 5c 01 11 21 29 |..!....!..)\..!)|
00000040 0f 6b 01 21 11 00 35 68 01 11 21 35 a6 0e 01 21 |.k.!..5h..!5...!|
00000050 11 00 a3 d6 01 11 21 a3 01 d7 01 21 11 00 71 a4 |......!....!..q.|
00000060 01 11 21 71 00 a4 01 21 11 00 a3 d6 01 11 21 a3 |..!q...!......!.|
00000070 01 d7 01 21 11 00 29 5c 01 11 21 29 0f 6b 01 21 |...!..)\..!).k.!|
00000080 11 00 35 68 01 11 21 35 a6 0e 01 21 11 00 a3 d6 |..5h..!5...!....|
00000090 01 11 21 a3 01 d7 01 21 11 00 71 a4 01 11 21 71 |..!....!..q...!q|
000000a0 00 a4 01 21 11 00 a3 d6 01 11 21 a3 01 d7 01 21 |...!......!....!|
000000b0 11 00 29 5c 01 11 21 29 0f 6b 01 21 11 00 35 68 |..)\..!).k.!..5h|
000000c0 01 11 21 35 a6 0e 01 21 11 00 a3 d6 01 11 21 a3 |..!5...!......!.|
My question now is that how can I get my serial_sensor to get these values using value templates? For example hex message 01 11 21 35 a6 would be a temperature reading that I want to display in Home assistant. Value A6 is NTC-sensor reading that would convert to decimal and celsius like this: A6=166 (decimal)=22(celsius) according to communication protocol from manufacturer of the unit. I have been trying to study manuals like there is no tomorrow but I need some help to get started as I am a newbie in this kind of programming.
I would have exactly the same use case. I also have a Vallox ventilation system and have always operated it with OpenHAB via a serial adapter until today. Now I have switched to Home Assistant and there is no solution out of the box for the old ventilation system. Have you found a solution in the meantime? Can you share the code?
I did find a readymade solution. The guy who designed it has pretty good instructions in his blog: Guide: Vallox Digit Ventilation to Home Assistant (Part 1/2 – hardware) – Creating Smart Home
