Hi, this is my first post and I’ve been searching about this topic without luck yet. I hope it’s not duplicated elsewhere.
A while ago I started building a (wired) alarm system for my house in HA. First I tried with the GPIO pins of the Rpi, but it was a disaster because of false alarms or simply not detecting binary sensors correctly. After that I moved to my current setup: an ESP32 cia MQTT, but I’m concerned about the stability of the system if someone tries to jam the wifi signal.
What I would like to do is build a backup using something like serial communication between the ESP32 and the Rpi, as they will be only a couple inches away in their final location, to trigger the alarm if opening (state change) is detected wia MQTT or serial. Is there a way to do this?
I think I’m quite lost yet, but what I’ve done so far is to add uart to the ESP32 at in the EspHome dashboard and configuration.yaml.
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 115200
- platform: serial
serial_port: /dev/ttyACM0
baudrate: 115200
But I don’t know how to retrive the sensor information: value_template or Json maybe?
Any ideas on how to achieve this?
Thanks!
