Serial Port Sensors dropping off dashboard when no value recieved
Hi Everyone,
I’ve been using my HA for in a basic way for a few months now. Now I’m trying to build a factory monitoring system. I want to display power being used and generated with our solar panels. Along with water temp and compressed air pressure of the factory.
I have stand alone ESPHome unils running both the water and compressed air sensors. These seem to work great .
My main issue is my data from my Lechacal RPICT4V3 doesn’t always bring a data feed via the Serial port.
This is my configuartion.yaml file.
 - platform: serial
   serial_port: /dev/ttyAMA0
   baudrate: 38400
   sensors:
     rpict_ct1:
       friendly_name: CT1
       unit_of_measurement: "W"
       value_template: "{{ states('sensor.RPICT').split(' ')[1] | float }}"
     rpict_ct2:
       friendly_name: CT2
       value_template: "{{ states('sensor.RPICT').split(' ')[2] | float }}"
     rpict_ct3:
       friendly_name: CT3
       value_template: "{{ states('sensor.RPICT').split(' ')[3] | float }}"
     rpict_irms1:
       friendly_name: Irms1
       unit_of_measurement: "A"
       value_template: "{{ states('sensor.RPICT').split(' ')[4] | float }}"
     rpict_irms2:
       friendly_name: Irms2
       value_template: "{{ states('sensor.RPICT').split(' ')[5] | float }}"
     rpict_irms3:
       friendly_name: Irms3
       value_template: "{{ states('sensor.RPICT').split(' ')[6] | float }}"
     rpict_irms4:
       friendly_name: Irms4
       value_template: "{{ states('sensor.RPICT').split(' ')[7] | float }}"
     rpict_voltage1:
       friendly_name: V1
       unit_of_measurement: "V"
       value_template: "{{ states('sensor.RPICT').split(' ')[8] | float }}"
     rpict_voltage2:
       friendly_name: V2
       value_template: "{{ states('sensor.RPICT').split(' ')[9] | float }}"
     rpict_voltage3:
       friendly_name: V3
       value_template: "{{ states('sensor.RPICT').split(' ')[10] | float }}"
     rpict_average_amps:
        friendly_name: Average Amps
        value_template: "{{ ((states('sensor.RPICT').split(' ')[5] |float + states('sensor.RPICT').split(' ')[6] |float +  states('sensor.RPICT').split(' ')[7] |float) / 3) | round(0) }}"
     rpict_average_voltage:
        friendly_name: Average Voltage
        value_template: "{{ ((states('sensor.RPICT').split(' ')[8] |float + states('sensor.RPICT').split(' ')[9] |float +  states('sensor.RPICT').split(' ')[10] |float) / 3) | round(0) }}"
     rpict_kva:
        friendly_name: Current kVA
        unit_of_measurement: "kVA"
        value_template:  "{{ ((3 * ((states('sensor.RPICT').split(' ')[5] | float + states('sensor.RPICT').split(' ')[6] | float + states('sensor.RPICT').split(' ')[7] | float ) / 3)) * ((states('sensor.RPICT').split(' ')[8] | float +  states('sensor.RPICT').split(' ')[9] | float +  states('sensor.RPICT').split(' ')[10] | float ) / 3 ) / 1000) | round(0) | float  }}"
     rpict_current_kwh:
        friendly_name: Current kWh
        unit_of_measurement: "kWh"
        unique_id: current:info:kWh
        entity_id: sensor.rpict_current_kwh
        value_template: "{{ ((((states('sensor.RPICT').split(' ')[2] | float ) + (states('sensor.RPICT').split(' ')[3] | float )) * 1.5 ) / 1000) | round(0) | float }}"
I’m trying to work out how I can get my sensors to show correctly and hold the last value if a nan value is pulled in via the serial port. I’m not great at this coding and looking for a nudge in the correct direction. Any Help would be greatly appreciated…
