I made and arduino lighting detector that sends information down the usb port. It sends a 3 digit number starting with the middle around 512 then moves up and down. That is not the issue. I create the sensor. I can see it in the lovelace card. When I click on it. It will not give a history. It stops the system. It will not keep running. So then I tried to create it with a value_template.
- platform: serial
baudrate: 115200
serial_port: /dev/ttyACM0
value_template: "{{ states('sensor.serial_sensor') | float }}"
This keeps telling me unknown on the data. I tried with out the float and still did the same thing. When lighting comes. I need to see the results on the graph to get this to do automations. But I have to see the numbers. There come in so fast that you can no see it on a bar graph. I need a line graph. But how can I get this to start displaying the numbers in a usable way to not keep the system from slowing down.
Any ideas welcome.
