Hello
I’m trying to receive data string from my powermeter in my hassio with serial sensor
the power meter sends this string
490.74,235.27,3.05,0.68, 726.72,233.05,3.67,0.85, 208.93,235.24,1.14,0.78, 17864.96,84042.15
every second
- platform: serial
serial_port: /dev/ttyUSB0
baudrate: 115200
sensors:
my_powermeter_sensor_l1w:
friendly_name: L1_W
unit_of_measurement: "W"
value_template: "{{ states('sensor.serial_sensor').split(',')[1] | float }}"
my_powermeter_sensor_l1v:
friendly_name: L1_V
unit_of_measurement: "V"
value_template: "{{ states('sensor.serial_sensor').split(',')[2] | float }}"
my_powermeter_sensor_l1a:
friendly_name: L1_A
unit_of_measurement: "A"
value_template: "{{ states('sensor.serial_sensor').split(',')[3] | float }}"
my_powermeter_sensor_l1cosphi:
friendly_name: L1_cosphi
unit_of_measurement: "Q"
value_template: "{{ states('sensor.serial_sensor').split(',')[4] | float }}"
my_powermeter_sensor_l2w:
friendly_name: L2_W
value_template: "{{ states('sensor.serial_sensor').split(',')[5] | float }}"
my_powermeter_sensor_l2v:
friendly_name: L2_V
value_template: "{{ states('sensor.serial_sensor').split(',')[6] | float }}"
my_powermeter_sensor_l2a:
friendly_name: L2_A
value_template: "{{ states('sensor.serial_sensor').split(',')[7] | float }}"
my_powermeter_sensor_l2cosphi:
friendly_name: L2_cosphi
value_template: "{{ states('sensor.serial_sensor').split(',')[8] | float }}"
my_powermeter_sensor_l3w:
friendly_name: L3_W
value_template: "{{ states('sensor.serial_sensor').split(',')[9] | float }}"
my_powermeter_sensor_l3v:
friendly_name: L3_V
value_template: "{{ states('sensor.serial_sensor').split(',')[10] | float }}"
my_powermeter_sensor_l3a:
friendly_name: L3_A
value_template: "{{ states('sensor.serial_sensor').split(',')[11] | float }}"
my_powermeter_sensor_l3cosphi:
friendly_name: L3_cosphi
value_template: "{{ states('sensor.serial_sensor').split(',')[12] | float }}"
my_powermeter_sensor_whout:
friendly_name: WH_out
unit_of_measurement: "Wh"
value_template: "{{ states('sensor.serial_sensor').split(',')[13] | float }}"
my_powermeter_sensor_whin:
friendly_name: Wh_in
value_template: "{{ states('sensor.serial_sensor').split(',')[14] | float }}"
but in the states all I get is an unavailable
log:
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L2_A: UndefinedError: list object has no element 7
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template Wh_in: UndefinedError: list object has no element 14
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L2_cosphi: UndefinedError: list object has no element 8
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L3_W: UndefinedError: list object has no element 9
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L1_A: UndefinedError: list object has no element 3
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L1_W: UndefinedError: list object has no element 1
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L3_V: UndefinedError: list object has no element 10
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L3_A: UndefinedError: list object has no element 11
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L1_cosphi: UndefinedError: list object has no element 4
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L2_W: UndefinedError: list object has no element 5
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L3_cosphi: UndefinedError: list object has no element 12
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template WH_out: UndefinedError: list object has no element 13
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L2_V: UndefinedError: list object has no element 6
2020-03-26 15:58:10 ERROR (MainThread) [homeassistant.components.template.sensor] Could not render template L1_V: UndefinedError: list object has no element 2
thank you
