First off I’m a donkey and didn’t get any full backups before the crash. Didn’t understand that the backups I saw happening were partial
Long story short, the windows 10 os drive that the HA VM (virtual box) resides on went bad, but I was able to clone it to another SSD. I replaced the cable to a non-right angle cable and it ended up being a bad cable that caused windows to crash and the vm along with it. I got the cable figured out and replaced but my HA server is in a bad way.
The web interface just says “unable to connect to home assistant” so I can’t do anything via the web interface. The CLI looks ok but when I try to restart core it tells me to check the supervisor and the supervisor logs show:
Core check is successful, but restarting it fails and points me at the sup logs.
An assistant is appreciated.
EDIT: Poking around more I found others with the same issue and they indicated the core.config file could have entries in it to disable to figure out if something is causing the crash. But when I inspect that directory I see some corrupted files. These files appear the same as the regular core.config file when using vi.
