I would like to see a Start option added to the Configuration/Server Controls/Server Management . This would be used after you have Stop(ped) HA and want to restart it without having to reboot the PI.
If HA is not running you do not have access to that page or any other part of the UI.
SSH into HA and use the command ha core start
Thank you, thank you. Why I requested this option is because each time I stopped HA I needed to reboot to get HA restarted. I tried multiple commands to restart without a reboot but all failed because they were obviously the wrong commands. Yours, on the other hand, works perfectly. Nothing more needed
You’ll probably find this page helpful.
Now if only I can get HA to STOP when I issue the ha core stop command or select stop from the Server Control option on the web interface. At least 3 out of 4 times HA restarts instead of stops. Very frustrating…
