Service/action to turn off light invoked but not referenced
When I open the main gate or one of the garage doors, a yard light gets turned on. When it’s turned on, a timer is started. When the light is turned off, the timer gets cancelled, otherwise the timer runs out and the light will be turned off.
My very strange scenario is that when the gate gets opened, there are three triggers of my automation and one of them reports to be turning off the light, even though that action isn’t referenced.
How is it possible for that middle logbook entry to have happened?
Automation that turns on the light and starts a timer:
  - alias: "Switch On Front Door Light When Any Cover Opened"
    initial_state: true
      platform: state
      entity_id:
        - cover.main_gate
        - cover.garage_doors_lhs
        - cover.garage_doors_rhs
      to: "open"
    mode: queued
    condition:
      - condition: and
        conditions:
          - condition: or
            conditions:
              - condition: sun
                after: sunset
              - condition: sun
                before: sunrise
          - condition: state
            entity_id: light.front_door
            state: "off"
      - service: script.turn_on
          entity_id: script.turn_on_light_and_timer
          variables:
            light: light.front_door
            duration: "00:03:00"
The script used above:
script:
  turn_on_light_and_timer:
    description: "Turn on a light and its corresponding timer"
    fields:
      light:
        description: "A light entity"
        example: "light.my_light"
      duration:
        description: "A duration in %H:%M:%S format"
        example: "00:03:00"
    mode: single
    sequence:
      # https://www.home-assistant.io/docs/scripts/conditions/
      - service: light.turn_on
          entity_id: "{{ light }}"
      - service: timer.start
          entity_id: "{{ light | replace('light.', 'timer.') }}_timer"
          duration: "{{ duration }}"
Automation that turns off a light when the corresponding timer has run out:
  - alias: "Switch Off Light When Timer Expires"
    initial_state: true
      # same entities as for "Stop Light Timer If Running When Light Turned Off"
      - platform: event
        event_type: timer.finished
        event_data:
          entity_id: timer.living_room_lamp_timer
      - platform: event
        event_data:
          entity_id: timer.front_door_timer
      - platform: event
        event_data:
          entity_id: timer.foyer_timer
      - platform: event
        event_data:
          entity_id: timer.kitchen_counter_timer
      - platform: event
        event_data:
          entity_id: timer.scullery_counter_timer
      - platform: event
        event_data:
          entity_id: timer.hallway_timer
      - platform: event
        event_data:
          entity_id: timer.bedroom_bedlamp_timer
    mode: parallel
      - service: light.turn_off
          entity_id: "{{ trigger.event.data.entity_id | replace('_timer', '') | replace('timer', 'light') }}"
Definition of my cover, in case that’s helpful:
cover:
    covers:
      main_gate:
        friendly_name: "Main Gate"
        device_class: gate
        open_cover:
          # https://community.home-assistant.io/t/cover-template-open-close/248449
          - condition: state
            entity_id: binary_sensor.main_gate_gate_status
            state: "off"
          - service: switch.turn_on
              entity_id: switch.main_gate_remote
        close_cover:
          - condition: state
            state: "on"
        stop_cover:
        # true (on) means open
        value_template: "{{ is_state('binary_sensor.main_gate_gate_status', 'on') }}"
        icon_template: >-
          {%- from 'security.jinja' import get_cover_icon -%}
          {{ get_cover_icon('binary_sensor.main_gate_gate_status', 'binary_sensor.main_gate_alert', 'mdi:gate') }}
        availability_template: "{{ not is_state('binary_sensor.main_gate_gate_status', 'unavailable') }}"
