Herbert01
(Werner)
December 21, 2021, 5:59pm
1
Hi there,
I would like to be able to turn on the air conditioning in my car as a switch in the Lovelace.
To do this, I would have to run the following service:
bmw_connected_drive.activate_air_conditioning
How do I get a service integrated as a switch.
Greetings Werner
Herbert01
(Werner)
December 21, 2021, 6:37pm
2
Hi there,
I managed it myself with a map.
Now I would like to use this service in my HUE emulation via Alexa.
Currently my code for the HUE emulation looks like this:
emulated_hue:
host_ip: 192.168.173.71
listen_port: 80
expose_by_default: false
entities:
light.iluminize_hk_zd_rgbcct_a_level_light_color_on_off:
hidden: false
script.kueche_jalousie_leichter_blenschutz:
name: "Leichter Sonnenschutz"
hidden: false
script.kueche_jalousie_voller_blenschutz:
name: "Voller Sonnenschutz"
hidden: false
switch.luefterszkg_timer:
hidden: false
How can I do a service there (``
integrate?
Greetings Werner
You can create your own switch like this: Template Switch - Home Assistant
Herbert01
(Werner)
December 22, 2021, 10:12am
4
Hello and thanks for the answer.
Unfortunately I don’t understand the instructions.
I was able to integrate the air conditioning into the Lovelace.
Only not in the HUE emulation.
Would it be so correct :?
emulated_hue:
listen_port: 80
entities:
service.bmw_connected_drive.activate_air_conditioning:
name: "BMW Klima an"
hidden: false
I beginner.
Thanks for your patience.
Greetings Werner
