Service call with template
I would like to call the following service (zone cleaning for roborock vacuum)
                action: call-service
                service: vacuum.send_command
                  entity_id: vacuum.roborock_s8_pro_ultra
                  command: app_zoned_clean
                  params:
                    - - 19608
                      - 31338
                      - 23947
                      - 34364
                      - 1
instead of using a “1” in the last line, i would like to use
- {{states('input_select.roborock_durchlaufe')}}
but after saving (its used in a button card), its replaced with
"[object Object]": null
Using
- "{{states('input_select.roborock_durchlaufe')}}"
does not work.
Any ideas?
Thank you for your support.
Use a script:
Where are you trying to set this up?
The action key of an automation shouldn’t have call-service after it, and card actions do not normally accept templating at all.
