2021.3 release came up with a great new UI, however, my instance produces no areas, although I have 15. Is this familiar?
Got the same issue when creating automations. “No matching areas found” when I try to select lights’ areas - even thoug the areas are available in the Configuration --> Areas section.
I have it too. Not sure if it’s a bug or the feature isn’t fully implemented
Same here although if I select the service Switch: Turn_off no matching areas found but if Light: Turn_off selected one selected area is found. This is despite there being multiple lights and switches in all 13 areas. Must be a bug.
This seems to be fixed in 2021.4
