I have the hue integration setup and everything is working fine. I would like to triggger a hue scene from an automation, but the service hue.hue_activate_scene is not available. According to the documentation it should be available. I have the V2 bridge.
Same here. It happens occasionally. Reboot worked. But it’s not really a solution, when automations, scripts or buttons are depending on it. Any ideas as to the cause of the service going awol?
I’m having the same problem, a hard reset of my home assistant computer brought the service back - but I’m hesitant to rely on this service for automations now
I am just re-creating the scenes in HA and calling them directly. The light turn on service is mostly reliable with Hue, every once in a while one light missed the instruction so I often run the scene twice in a row.
I just got this on freshly installed Home Assistant 2021.3.2 version. Not sure I’d this made any difference but it was working normally, then I turned on showing hue light groups. After some time I tried the automation with the hue service and the service just wasn’t there. Lights were still detected.
