I’m creating a custom component which has a service. This is defined in services.yaml and working fine in yaml mode. However, when I switch to UI Mode in the services tab under developer tools, there are no UI controls.
I’ve also replaced my inputs with some other content from various components out there to see if my code is wrong. It’s my first attempt at doing a custom component, so I bet I’m blatantly overlooking some basic requirement, but I can’t seem to find anywhere what is missing or some code samples anywhere…
# Sample services.yaml content with just one field as an example
my_service:
description: Do something
fields:
volume:
required: true
example: 50
default: 50
selector:
number:
min: 0
max: 100
step: 1
unit_of_measurement: "%"
mode: slider
I’ve kept this sample generic. I can add more controls if someone can point me in the right direction as to why the volume field does not display in UI mode for this sample. Thanks!
Thanks! To clarify, I’ve got the service registered, the service handler working (for yaml input from the front end service call) and the python script is handling that data ok.
I was under the impression that as long as you define the UI components in services.yaml, you can simply use those input values from the front-end in the service handler (again since it works when setting those in yaml in the service call…). So not quite if I interpret your response right and looking at that repository, some more learning to do here
