Service input_boolean.turn_on not work in Automation
HI all.
I have a problem with a service input_boolean.turn_on and input_boolean.turn_off in automation.
This is my automation.
alias: IrrigazionePy
description: ""
  - platform: time
    at: input_datetime.zone1_time1_starttime
  - platform: time
    at: input_datetime.zone1_time2_starttime
  - platform: time
    at: input_datetime.zone1_time3_starttime
  - platform: time
    at: input_datetime.zone1_time4_starttime
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: input_boolean.turn_off
            data: {}
              entity_id: input_boolean.zone1_time1_go
      - conditions:
        sequence:
              entity_id: input_boolean.zone1_time2_go
            data: {}
      - conditions:
        sequence:
              entity_id: input_boolean.zone1_time3_go
            data: {}
      - conditions:
        sequence:
              entity_id: input_boolean.zone1_time4_go
            data: {}
  - service: python_script.irrigation
    data_template:
      trigger: "{{ trigger.entity_id }}"
  - choose:
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
            data: {}
mode: single
The flow working fine but this action not work
         - service: input_boolean.turn_off  #(or turn_on)
            data: {}
In the automation trace I have this response
Result:
params:
  domain: input_boolean
  service: turn_off
  service_data: {}
    entity_id:
      - input_boolean.zone1_time1_go
running_script: false
limit: 10
If I use this instruction in a script, working fine.
Where am i wrong?
Regards,
Marco
Not sure what’s going on there. Your very first service call of the action should, I think, be a turn_on. The second block of code you pasted has indentation issues.
If the idea is to turn on the appropriate input_boolean, run the script, then turn it off again, try this much shorter version:
  - platform: time
    at:
      - input_datetime.zone1_time1_starttime
      - input_datetime.zone1_time2_starttime
      - input_datetime.zone1_time3_starttime
      - input_datetime.zone1_time4_starttime
    variables:
      idx: "{{ trigger.entity_id[25] }}"
      entity_id: input_boolean.zone1_time{{ idx }}_go
The indentation was created by UI automation and the flow is correct.
Yes, the first action is wrong, I correct it but have the same result.
I have try your code, is more “light”, but the problem is the same.
Executed: 11 maggio 2023 alle ore 15:28:00
Result:
params:
  service: turn_off
  service_data: {}
    entity_id:
limit: 10
The turn_on\turn_off not working
This bit from your post is wrong, but probably a pasting error.
Why do you think it’s not working? The log you pasted does not show a problem — that’s exactly what a log looks like on my system when it is working.
Executed: 11 May 2023 at 14:34:27
Result:
params:
  service: turn_on
  service_data: {}
    entity_id:
      - input_boolean.ch_away
limit: 10
Can you paste the history graph for input_boolean.zone1_time1_go like this:
Yes a cut&paste problem.
I thought it was wrong for: running_script: false
I thought “false” meant not executing the command
In any case this is the history, the boolean has never been activated
Are you sure? What are the four lines after 13:00?
Try adding a delay into the action so you can see if it changes. Note that you cannot manually run the automation because of the references to trigger.entity_id — you must trigger it with one of the input_datetimes.
  - delay: "00:03:00"
You are right!
I’m an idiot, the problem is the python script that fails because I realized now that the shelly it’s supposed to activate is offline, so the python immediately terminates and the boolean goes back to offf
I hadn’t noticed the lines!
Thanks!
We all are at times. At least you have a shorter automation now.
