Service light.turn_on not available in dropdown
Hey guys!
I started working with HA this week and I tried to follow this example: Automating Home Assistant - Home Assistant (home-assistant.io)
After choosing “Service” I wanted to choose “light.turn_on” but this entry is not available in the dropdown list (see screenshot). How can I get this service?
I set an ESP8266 as light with this code:
output:
  - platform: gpio
    pin: D1
light:
  - platform: binary
    output: gpio_d1
I can turn on the ESP by toggling the switch in dashboard.
Many thanks in advance!
Regards
Stefan
Do you have light: somewhere in your homeassistant configuration?
i was thinking the same, service light.turn_on will only be available when there are light devices…
and i have:
If you have you lights configured as switches it would be switch.turn_on. You can see the domain of your entities in the developer tools.
@anon43302295 From my point of view I configured an ESP as light (see code in first post). Isn’t this what you mean?
@Syntox Right now I don’t have access to my HA, but can you please tell me where within the developer tools I can find the “real” domain of my entities?
In the states menu.
Your entities will be of the form domain.object_id e.g. light.bedroom or switch.bedroom
The developer tools are located in the sidebar:
I’m wondering about the -platform binary…
shouldn’t that be:
light:
  - platform: switch
    name: Light Kitchen Window
    entity_id: switch.kitchen_window
(this is a copy of my own config)
I think ‘binary’ is only used for sensors (=input)
Didn’t knew you could use switch but I use binary too and it works fine.
Binary sensors gather information about the state of devices which have a “digital” return value (either 1 or 0). These can be switches, contacts, pins, etc.
Oh, you’re talking about the HA config. For ESPHome I think I didn’t configure anything there. The config he posted above is the ESPHome config
EDIT: But I have light: in my HA config
Okay, to prevent more misunderstandings:
I have an ESP8266.
First I defined it as switch and I was able to control it manually.
Then I started the next step and wanted to set it as light, so I used the code I found on GitHub (as posted above).
It seems that this setting is not working (because the service light.turn_on) is not available - I’ll check that this afternoon - thanks so far for this advice.
I’ll also try the suggestion from @aceindy to use this combination:
light:
  - platform: switch
    output: gpio_d2
switch:
  - platform: gpio
    pin: 2
That shoul work, shouldn’t it?
@Syntox: Thanks for your last post - I think you’re right, I configured that in ESPHome config - what would I need to configure in the HA config then to set my ESP entity as light?
my bad…didn’t see that :yum:
I don’t think this works
as he posted his HA config.
If you look at config > integrations does your ESPHome node shows up in the ESPHome card? And is it a light if you click on the node > entities (light.lamp)?
Hmm…
i think defining it a switch in ESPhome works in combination with HAconfig defining the light from platform switch :yum:
light:
  - platform: switch
This is how i changed from switch to light :wink:
sure this works too but it’s just an extra step you usually don’t need.
BTW this s my ESPHome config:
output:
  - platform: gpio
    pin: GPIO12
light:
  - platform: binary
    output: relay
    restore_mode: RESTORE_DEFAULT_OFF #this is just to ensure that the light is off if the ESP reboots
My switch is not on ESPHome, so i need it :wink:
Sooo - I got it to work now:
ESPHome config:
switch:
  - platform: gpio
    pin: 2
HA config:
light:
  - platform: switch
    entity_id: switch.esp8266_switch
Thank you guys!
You’re welcome :wink:
Good to know you got it working!
I tried it myself yesterday with a new D1 mini. First I configured a switch and that worked.
Then I deleted that switch from the esp config and added a binary light and for my surprise the esp didn’t got discovered. I had to manually add it by typing in the IP of the D1 mini. Maybe that was your problen too…
