Service - prefill datetime selector
I am trying to modify a home assistant core component
to add some more functions.
So far its working but I am not able to prefill the current date time and the current time - 1 hour.
services.yaml
remove_clients_by_date:
  description: "Removes clients whose `first_seen` is within a specific time range."
  fields:
    start_date:
      required: true
      description: "The start date in ISO 8601 format. Clients first seen after this date will be removed."
      example: "2025-01-01T00:00:00"
      selector:
        datetime: {}
    end_date:
      required: true
      description: "The end date in ISO 8601 format. Clients first seen before this date will be removed."
      example: "2025-01-20T00:00:00"
      selector:
        datetime: {}
this is how it looks
Afaik template scripting is not working inside the service.yaml files.
setting a date inside the service.py
SERVICE_REMOVE_CLIENTS_BY_DATE_SCHEMA = vol.Schema(
        vol.Optional(CONF_START_DATE, default="2024-01-19T12:00:00"): vol.Coerce(datetime.fromisoformat),
        vol.Optional(CONF_END_DATE, default="2024-01-19T13:00:00"): vol.Coerce(datetime.fromisoformat),
doesnt change anything
Any idea ?
I don’t think this will be possible. Only default you can use is a fixed value in the services.yaml
OK, thx for your reply. :slight_smile:
