I am now using Home Assistant at work on a RPI3 and I have a load of binary ping sensors added to check switches around campus as well as physical and virtual servers. I had these all pinging at 30 second intervals but found the due to the amount being pinged it would occasionaly miss packets and trigger an “offline alert” to us.
To combat this my automation for offline alerts states this:
to: 'off'
for:
minutes: 1
seconds: 30
This works fairly well however I have an “up alert” to indicate to us when it comes back online. The only problem is if it fails a ping and goes from on to off and then back to on before 1 minute 30 it triggers an up alert even though we never received a down alert.
Can anyone thing of a simple way to combat this without me having to add another whole load of sensors, maybe toggles for each thing I am monitoring.
It is per sensor as I don’t know of any other way of doing it. Although while typing that I just thought about groups!
Here is the automation for offline alert:
- id: '1579126062579'
alias: HP Core Offline
description: Triggers an alert when the HP Core goes offline
- entity_id: binary_sensor.hp_core
platform: state
to: 'off'
for:
minutes: 1
seconds: 30
condition:
- condition: state
entity_id: input_boolean.maint_mode
state: 'off'
- service: notify.it_team
message: The HP Core Stack appears to be offline for 2 attempts!
title: 'Offline Alert: HP Core Stack'
- service: notify.it_sms
- service: rest_command.network_alert
msg: "HP Core Stack Offline"
Here is the code for the online alert:
- id: '1579126062579O'
alias: HP Core Restored
description: Triggers an alert when the HP Core is Restored
platform: state
to: 'on'
message: The HP Core Stack appears to be Restored!
title: 'Restored: HP Core Stack'
- service: rest_command.network_warn
msg: "HP Core Stack Restored"
