i am very new to coding and have been trying to make a card to call Alexa tts with help from some others but im stuck on the final button when pressing announce to run the script to send the message to the Alexa device i get “Service script.send_alexa_announcement not found.”
the script is named correctly so I’m not sure why it is unable to call it and it runs normally when i manually run it in the script but the card button refuses to call it on acoount that it “cant be found”
here are some pictures of what everything looks like, thanks for any help!!
I have a similar problem. Script and it’s ID exist and are correct, but the automation complains it doesn’t exist. I find this happens if when the script is created it has a different ID and that ID is then changed.
I just had this problem, and tried everything yesterday. This was what worked. Copied the yaml, deleted the automation, created a new and pasted the yaml. All in the UI, now it finds it.
I think I might have renamed the script once early on yesterday, that might have been the reason.
I just experienced the same in 2025.10.x. The script would not be available under the displayed name, no matter what I tried. I renamed it, renamed it back, nothing.
Pretty frustrating issue, honestly.
This should really be looked into. That said, I also ‘fixed’ it with the same approach (copy YAML, delete, recreate, paste YAML), so now I cannot investigate what caused this internally.
Just experienced this issue myself today. Renamed a script, and banging my head against the wall trying to figure out why HA thinks it doesn’t exist. This should really be addressed.
