I have two long automations that are identical except for a single service in the middle.
These different services both have data passed to them, but not the same parameters.
Is there any way to do this? ‘Mismatched’ data is not allowed i.e. if I define all parameters and pass them all to both services it produces an error because neither service expect the same data.
The only way around this as far as I can tell is to call a script with all the data parameters and have that script then call the necessary service. (HA of won’t create a ‘mismatch’ error on the script receiving the ‘wrong’ data).
So to illustrate:
- alias: my_automation
# My two automations have a different trigger
# Trigger in automation 1
- platform: mqtt
topic: topic/first_trigger
# Trigger in automation 2
- platform: mqtt
topic: topic/second_trigger
#--- Some actions here ---#
# This is the only service in the whole automation that is different
# For example this...
- service: tts_google_say
data_template:
my_boolean: "{{ input_boolean.my_boolean }}"
# ...or this
- service: media_player.play_media
data_template:
my_input_text: "{{ input_boolean.my_input_text }}"
# And I can't do this to combine them in one automation
- service_template: >
{% if trigger.topic == 'topic/first_trigger' %}
tts_google_say
{% else %}
{% endif %}
data_template:
#--- Loads more actions ---#
(I know those service calls aren’t consistent with the data, it is just a very simplified example.)
Yes, that is what I wanted to do but both services take different data parameters and HA checks that the passed parameters match those the service expects to receive. Unless the service is a script in which case it doesn’t know what the called script is expecting.
I call a script and do it that way but then I’d need to move everything in the automation that comes after the service_template into another script as well. Not a big deal but I just wanted to make sure there wasn’t another, cleaner way to do this that I didn’t know about.
I still don’t get it You should be able to adjust your data_template accordingly.
I think you should be able to template the parameters as well.
I think it would be easier for me to understand if you post the two service calls you want with the parameters you want for them and the values that the parameters should have.
@petro Yes that is the only way I could see to do it (call separate scripts) and that would be fine but it brings the drawback that everything in the automation following those service calls also has to be moved into a third script because there is no 100% foolproof way to know when a script has finished.
I’m not sure doing it that way is any better than the duplicated code I have now.
I don’t use appdaemon but the python script looks interesting. Even if I don’t use it, it has taught me something.
Do all python scripts absolutely have to be in the python_scripts folder? Is there a way !include or redirect an any way. I use packages and it would make sense to be able to keep python scripts in the package.
And as an aside, do you know if there is particular reason HA was designed to check data parameters passed to ‘built-in’ services? After all it doesn’t (can’t) check when the service is script.
I believe they all have to be in the python_scripts folder. I don’t know if include will work. I don’t use them. So my knowledge is just the API and some use cases.
I believe it’s just the way it was coded. It would be nice if you could just pass a bunch of random crap.
