I found this strange behavior I can’t find a way to solve.
Consider this service_template that will work:
service_template: > {% if states.light.lampe_christine.state == 'on' %} light.turn_off {% else %} light.turn_on {% endif %}
now if I replace the entity by this one
service_template: > {% if states.light.6001949557bd_1921681149.state == 'on' %} light.turn_off {% else %} light.turn_on {% endif %}
it will fail during check_config
Failed config
automation:
- Invalid config for [automation]: invalid template (TemplateSyntaxError: expected token 'end of statement block', got 'bd_1921681149') for dictionary value @ data['action'][0]['service_template']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 39). Please check the docs at https://home-assistant.io/components/automation/
I’m not sure how to address this problem.
Edit: this entity exist
light.6001949557bd_1921681149 on brightness: 255
effect_list: random,gb_cross_fade,white_fade,green_fade,white_strobe,yellow_fade,colorjump,cyan_strobe,blue_fade,yellow_strobe,rb_cross_fade,blue_strobe,purple_fade,colorstrobe,purple_strobe,colorloop,green_strobe,cyan_fade,red_strobe,red_fade,rg_cross_fade
rgb_color: 255,64,0
friendly_name: RGB-Strip-JP-Desk
supported_features: 21
icon: mdi:led-strip
