I’m trying to send the input_select STATE inside a MQTT payload (within the “args” option) but not sure if it can be done or how to write it:
Please see the automation below where it says <— INSERT INPUT_SELECT.GAME_SELECT STATE HERE —> this is where I need the selection from the input_select.game_select entitiy.
I’m using IoT Link to send commands to a Windows PC and trying to use a dropdown list box to select a game which will then send the MQTT payload to the computer (arcade) and start the selected game (input_select.game_select).
The input_select.game_select STATE needs to be inserted in the middle (“args”) of the payload… is this possible please?
input_select:
game_select:
options:
- kinst
- mk3
- pblank
initial: kinst
- id: '158941234354'
alias: start selected game
platform: state
entity_id: input_select.game_select
service: mqtt.publish
data_template:
topic: iotlink/workgroup/arcade/commands/run
payload: '{ "command": "C:\\Emulators\\mame_0219nonag\\mame64.exe", "args": "<--- INSERT INPUT_SELECT.GAME_SELECT STATE HERE --->" , "path": "C:\\Emulators\\mame_0219nonag", "user": "", "visible": true, "fallback": true }'
Thank you in advance
