I wonder if anybody can shed some light on whether the following is possible:
I have a binary sensor (sofa_occupied). When the sensor turns off I want to:
- pause the media player if it is playing
- turn off a fan if it is spinning
- turn off a light if it is on
When the switch turns back on I want to
- unpause the media player if it was previously playing
- turn the fan back on if it was previously on
- turn the light on if it is a certain time of day
I use input booleans to keep track of the media player and fan states at the time the sofa switch turns off.
I can do all of the above individually using service templates.
However, if I combine all of these in a single automation, it seems that the moment any of my if conditions is false, none of the actions that are listed further down in the automation get actioned. I guess this is intended behaviour - but is there a way around it?
I guess I could make individual automations for the 3 different entities, all with the same trigger - but that seems very clunky. Any advice is very welcome!
Here’s my two automations. In the first one, if it isn’t between 6:00 and 16:00, the daylight won’t turn on, but also none of the other actions are done. I’d like those to still run.
- id: '1579884607525'
alias: sofa_becomes_occupied
description: ''
- entity_id: binary_sensor.sofa_occupied
platform: state
to: 'on'
condition: []
- service_template: '{% if ''06:00'' < states.sensor.time.state < ''16:00'' %} switch.turn_on
{% endif %}'
entity_id: switch.daylight
- service_template: '{% if is_state(''input_boolean.was_media_playing'' , ''on'')
%} script.newtv_media_playpause {% endif %}'
%} input_boolean.turn_off {% endif %}'
entity_id: input_boolean.was_media_playing
- service_template: '{% if is_state(''input_boolean.was_fan_spinning'' , ''on'')
%} switch.turn_on {% endif %}'
entity_id: switch.downstairs_fan
entity_id: input_boolean.was_fan_spinning
- id: '1579899963808'
alias: sofa_becomes_empty
description: ''
platform: state
to: 'off'
condition: []
- service: switch.turn_off
- service_template: '{% if is_state(''binary_sensor.newtv_media_playing'' , ''on'')
%} input_boolean.turn_on {% endif %}'
- service_template: '{% if is_state(''switch.downstairs_fan'' , ''on'') %} input_boolean.turn_on
{% endif %}'
entity_id: inpout_boolean.was_fan_spinning
