Quick and dirty custom component that allows min/max adjustments. Fully backwards compatible with the existing input_number. Seems to work great with Lovelace, I didn’t test it on State UI. It clamps the value to min/max as appropriate and refuses to set min>=max or max<=min.
To change min/max use:
Services
input_number.set_min
input_number.set_max
Data:
"entity_id": "input_number.myinput",
"value": 1
Place this into config/custom_components
input_number.py
Component to offer a way to set a numeric value from a slider or text box.
For more details about this component, please refer to the documentation
at https://home-assistant.io/components/input_number/
import logging
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant.const import (
ATTR_ENTITY_ID, ATTR_UNIT_OF_MEASUREMENT, CONF_ICON, CONF_NAME, CONF_MODE)
from homeassistant.helpers.entity_component import EntityComponent
from homeassistant.helpers.restore_state import RestoreEntity
_LOGGER = logging.getLogger(__name__)
DOMAIN = 'input_number'
ENTITY_ID_FORMAT = DOMAIN + '.{}'
CONF_INITIAL = 'initial'
CONF_MIN = 'min'
CONF_MAX = 'max'
CONF_STEP = 'step'
MODE_SLIDER = 'slider'
MODE_BOX = 'box'
ATTR_INITIAL = 'initial'
ATTR_VALUE = 'value'
ATTR_MIN = 'min'
ATTR_MAX = 'max'
ATTR_STEP = 'step'
ATTR_MODE = 'mode'
SERVICE_SET_VALUE = 'set_value'
SERVICE_SET_MIN = 'set_min'
SERVICE_SET_MAX = 'set_max'
SERVICE_INCREMENT = 'increment'
SERVICE_DECREMENT = 'decrement'
SERVICE_DEFAULT_SCHEMA = vol.Schema({
vol.Optional(ATTR_ENTITY_ID): cv.entity_ids
SERVICE_SET_VALUE_SCHEMA = vol.Schema({
vol.Optional(ATTR_ENTITY_ID): cv.entity_ids,
vol.Required(ATTR_VALUE): vol.Coerce(float),
def _cv_input_number(cfg):
"""Configure validation helper for input number (voluptuous)."""
minimum = cfg.get(CONF_MIN)
maximum = cfg.get(CONF_MAX)
if minimum >= maximum:
raise vol.Invalid('Maximum ({}) is not greater than minimum ({})'
.format(minimum, maximum))
state = cfg.get(CONF_INITIAL)
if state is not None and (state < minimum or state > maximum):
raise vol.Invalid('Initial value {} not in range {}-{}'
.format(state, minimum, maximum))
return cfg
CONFIG_SCHEMA = vol.Schema({
DOMAIN: cv.schema_with_slug_keys(
vol.All({
vol.Optional(CONF_NAME): cv.string,
vol.Required(CONF_MIN): vol.Coerce(float),
vol.Required(CONF_MAX): vol.Coerce(float),
vol.Optional(CONF_INITIAL): vol.Coerce(float),
vol.Optional(CONF_STEP, default=1):
vol.All(vol.Coerce(float), vol.Range(min=1e-3)),
vol.Optional(CONF_ICON): cv.icon,
vol.Optional(ATTR_UNIT_OF_MEASUREMENT): cv.string,
vol.Optional(CONF_MODE, default=MODE_SLIDER):
vol.In([MODE_BOX, MODE_SLIDER]),
}, _cv_input_number)
}, required=True, extra=vol.ALLOW_EXTRA)
async def async_setup(hass, config):
"""Set up an input slider."""
component = EntityComponent(_LOGGER, DOMAIN, hass)
entities = []
for object_id, cfg in config[DOMAIN].items():
name = cfg.get(CONF_NAME)
initial = cfg.get(CONF_INITIAL)
step = cfg.get(CONF_STEP)
icon = cfg.get(CONF_ICON)
unit = cfg.get(ATTR_UNIT_OF_MEASUREMENT)
mode = cfg.get(CONF_MODE)
entities.append(InputNumber(
object_id, name, initial, minimum, maximum, step, icon, unit,
mode))
if not entities:
return False
component.async_register_entity_service(
SERVICE_SET_VALUE, SERVICE_SET_VALUE_SCHEMA,
'async_set_value'
SERVICE_SET_MIN, SERVICE_SET_VALUE_SCHEMA,
'async_set_min'
SERVICE_SET_MAX, SERVICE_SET_VALUE_SCHEMA,
'async_set_max'
SERVICE_INCREMENT, SERVICE_DEFAULT_SCHEMA,
'async_increment'
SERVICE_DECREMENT, SERVICE_DEFAULT_SCHEMA,
'async_decrement'
await component.async_add_entities(entities)
return True
class InputNumber(RestoreEntity):
"""Representation of a slider."""
def __init__(self, object_id, name, initial, minimum, maximum, step, icon,
unit, mode):
"""Initialize an input number."""
self.entity_id = ENTITY_ID_FORMAT.format(object_id)
self._name = name
self._current_value = initial
self._initial = initial
self._minimum = minimum
self._maximum = maximum
self._step = step
self._icon = icon
self._unit = unit
self._mode = mode
@property
def should_poll(self):
"""If entity should be polled."""
return False
@property
def name(self):
"""Return the name of the input slider."""
return self._name
@property
def icon(self):
"""Return the icon to be used for this entity."""
return self._icon
@property
def state(self):
"""Return the state of the component."""
return self._current_value
@property
def unit_of_measurement(self):
"""Return the unit the value is expressed in."""
return self._unit
@property
def state_attributes(self):
"""Return the state attributes."""
return {
ATTR_INITIAL: self._initial,
ATTR_MIN: self._minimum,
ATTR_MAX: self._maximum,
ATTR_STEP: self._step,
ATTR_MODE: self._mode,
async def async_added_to_hass(self):
"""Run when entity about to be added to hass."""
await super().async_added_to_hass()
if self._current_value is not None:
return
state = await self.async_get_last_state()
value = state and float(state.state)
# Check against None because value can be 0
if value is not None and self._minimum <= value <= self._maximum:
self._current_value = value
else:
self._current_value = self._minimum
async def async_set_value(self, value):
"""Set new value."""
num_value = float(value)
if num_value < self._minimum or num_value > self._maximum:
_LOGGER.warning("Invalid value: %s (range %s - %s)",
num_value, self._minimum, self._maximum)
return
self._current_value = num_value
await self.async_update_ha_state()
async def async_set_min(self, value):
"""Set new min value."""
minimum = float(value)
if minimum >= self._maximum:
_LOGGER.warning("Invalid minimum: %s (must be lower than maximum %s)",
return
# Adjust value to minimim if it is less than the new minimum
if minimum > self._current_value:
self._current_value = minimum
async def async_set_max(self, value):
"""Set new max value."""
maximum = float(value)
if self._minimum >= maximum:
_LOGGER.warning("Invalid maximum: %s (must be higher than minimum %s)",
maximum, self._minimum)
return
if maximum < self._current_value:
self._current_value = maximum
async def async_increment(self):
"""Increment value."""
new_value = self._current_value + self._step
if new_value > self._maximum:
new_value, self._minimum, self._maximum)
return
self._current_value = new_value
async def async_decrement(self):
"""Decrement value."""
new_value = self._current_value - self._step
if new_value < self._minimum:
return
