I use Hue motion sensor in different rooms to turn on/off the light when there is movement and darkness.
By default, the sensor measures brightness every 5 minutes or when motion is detected. This leads to the fact that when I leave a room it turns off the light after a short time, but also measured the brightness value in the room when the light was on. If I enter the room again after a short time, the light is not switched on, because the wrong brightness value is still present.
My idea to solve the problem was that I force the light sensor to update the value after the light was automatically turned off. I darkened a room and run the following automation several times:
alias: Neue Automatisierung
description: ''
- platform: time
at: '00:01:00'
condition: []
- service: homeassistant.update_entity
data: {}
entity_id: sensor.hue_motion_sensor_4_illuminance
mode: single
However, the measured light value has not adjusted. Do I have here possibly a thinking error?
