Services not showing up?
hello, i just noticed that my available services are not showing up any more? … is it something i did wrong in the config files? how can i fix this? thanks
Click on the dropdown button… Then you will see al the services of the domain…
i know that but why are the list of available services not showing up any more… like in this picture
Because that’s a very old version of home assistant… The version with a drop down menu is since very long active… When you come from a very old version, you will see the services on the right… The newer versions use drop down… How long has it been you have done any updates? From which version do you come?
