Serving static files
I would like to save some statics files, to be used on my dashboards.
For example, an image with my home plans, to place sensors on it.
I did not find any www folder. So, I created mine.
My file is now located on /config/www/home.png.
But I can’t access it. https://xxx.xxx.xxx/home.png, https://xxx.xxx.xxx/local/home.png, …
I think rights are fine, as all configuration files are root:root.
➜  www ls -al
total 36
drwxr-xr-x 2 root root  4096 Jul 21 21:34 .
drwxr-xr-x 9 root root  4096 Jul 21 21:22 ..
-rw-r--r-- 1 root root 27564 Jul 21 21:34 home.png
What am I missing ?
Thanks for your help.
Regards !
This is the documentation I used.
But I missed an important part :
If you’ve had to create the www/ folder for the first time, you’ll need to restart Home Assistant.
Problem solved, thank you.
