I’m working on automated blinds with an D1 mini and a DS3225 servo (25 kg). I uploaded the following code to the D1 mini and it all works great, but after setting a position, the servo gets real hot (read: more than 72 degrees celsius) I think this is way to hot and shouldn’t be necessary. Is this normal behaviour, or can this problem be avoided? Thank in advance!
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Servo Fallback Hotspot"
password: "xxxxx"
captive_portal:
# Enable logging
logger:
level: verbose
ota:
password: !secret ota_password
# Enable Web server.
web_server:
port: 80
# Enable Home Assistant API
api:
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
- delay: 1000ms
- lambda: 'id(my_servo).detach();'
- delay: 1000ms
- servo.detach: my_servo
output:
- platform: esp8266_pwm
pin: D3
frequency: 50 Hz
servo:
- id: my_servo
output: pwm_output
min_level: 3.0%
idle_level: 7.5%
max_level: 12.0%
dallas:
- pin: D1
update_interval: 10s
- platform: dallas
address: 0xA20300A2793F0128
name: "Temperatuur servo jaloezieën"
cover:
name: "jaloezieën servo keuken"
optimistic: true
open_action:
- servo.write:
level: -80%
- delay: 2500ms
close_action:
- servo.write:
level: 30%
- delay: 2500ms
stop_action:
This is the wiring:
