Servo motor button/switch/activation
Hello, I was wondering if you could help me create a button or switch for my servo. I have been looking through diffrent forums and documentation and I can not figure it out. I would like to use my servo to push the button, so it needs to go so far as to press it and come back to default state. I will attach my code for servo, while I know that i would need to follow this:
Configuring HA would be so much easier if those guides had a possible use not just a snipet of code that could be placed anywhere between config files.
If anyone had maybe similar buttons/switches programed I would be greatful for sharing the code and placment of it.
tl dr:
button/switch/activator to make servo preset movment.
esphome:
api:
    services:
    - service: control_servo
      variables:
        level: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
output:
  - platform: esp8266_pwm
    pin: D4
    frequency: 50 Hz
servo:
  - id: my_servo
    output: pwm_output
configuration.yaml file:
input_number:
  servo_control:
    initial: 0
    min: -10
    max: 100
    step: 1
    mode: box
automation:
  - alias: Write Servo Value to ESP
      platform: state
      entity_id: input_number.servo_control
      # Replace livingroom with the name you gave the ESP
      - service: esphome.temp_off_control_servo
        data_template:
          level: '{{ trigger.to_state.state | int }}'
Thank you in advance.
Jarek
There are complete examples in the cookbook section and the DIY examples section. https://esphome.io/#cookbook and https://esphome.io/guides/diy.html
I solved it with this code:
api:
  services:
      variables:
        level: float
      then:
        - servo.write:
output:
    pin: D7
    frequency: 50 Hz
binary_sensor:
  - platform: gpio
    pin: D3
servo:
  - output: 'gate_t'
cover:
    name: "Open Close Gate"
    optimistic: true
    lambda: !lambda |-
      if (id(top_end_stop).state) {
          return COVER_CLOSED;
      } else {
          return COVER_OPEN;
    open_action:
      - servo.write:
          level: -30.0%
      - delay: 500ms
      - servo.write:
          level: 100.0%
    close_action:
      - servo.write:
          level: -50.0%
      - delay: 500ms
      - servo.write:
          level: 100.0%
this code updates the status of microswitch that is open/closed pressed /unppressed by updating the little picture and make servo go and come back.
For anyone that might need it.
via Dr Zzs video on blinds and his config.
