Hello. I want to control servo motor with HASS. But I didn’t find any integration for the servomotor. I will be grateful for your help.
The best easy way is ESPHOME
Hello, the esphome solution is not working.
You can use this code: Esp8266 Window Blinds MQTT
@jjhtpc
Thanks,
As an example, I would like to add the Nodemcu v3 device I use in the aquarium with esphome. I need to add a new device with the system you’re talking about. I don’t want to add an Exra device.
You could just flash the device with this code. I believe esphome uses similar code, but this is a direct integration. I will say I think esphome is great and I use it for several devices.
