SERVO NOT WORKING. Using esp32 (not8266), ledc but stuck
I have esp32 and MG9666 servo that I cannot get to work together. I have read the espHome pages on Servo and ledc. LEDC and all of the similar threads on the community… nine of which give clear resolution.
  • The esp32 is connected via USB to my computer.
  • The Servo has independent 5 V power supply.
  • The esp32 ground, the independent 5v ground and the Servo ground are all connected together
  • The Servo Signal cable is connected to GPIO23 ( I have also tried it in other GPIO pins just in case).
  • I have followed the code and guidelines (although these are no many years old) provided by @Sitek Servo Example and used successfully by many (although most seem to use D1Mini and the 8266 platform)
  • I have zero response from the Servo.
One of you - far smarter than me - will probably spot my basic error, I hope you can as it is driving me nuts!
My Servo.yaml file is:
esphome:
  friendly_name: blast-gateA1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "For me to know"
  services:
    - service: control_servo
      variables:
        level: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
ota:
  password: "also for me to know"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Blast-Gatea1 Fallback Hotspot"
    password: "still a secret"
captive_portal:
servo:
  - id: my_servo
    output: pwm_output
    auto_detach_time: 2s
output:
  - platform: ledc
    pin: GPIO23
    frequency: 50 Hz
In my main configuration.yaml I have added:
input_number:
  servo_control:
    initial: 0
    min: -100
    max: 100
    step: 1
    mode: slider
and in my automations .yaml I have added:
- id: '1688163524437'
  alias: slider
  description: ''
  - platform: state
    entity_id:
    - input_number.servo_control
  condition: []
  - service: esphome.blast_gatea1_control_servo
    data_template:
      level:'{{ trigger.to_state.state | int }}'
  mode: single
