Hi guys,
I’m new here and hope you can help me. I’m no programmer, just a specialist in copy/paste
I want to control a servo out of home assistant via an esp home installation on an esp32.
I’ve used the guide from siytek but can’t get it up and running…
The servo doesn’t move. Any ideas why???
thx Karl
code:
esphome:
friendly_name: ESPHomeAusheizer4
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "nO0stD3hQooFotpnR8XoCdnRG2ng1xxxxxxxxxxxx"
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-F855A8"
password: "xxxxx"
captive_portal:
dallas:
- pin: GPIO19
- platform: dallas
address: 0xa30417c1f2xxxxx
- platform: dht
pin: GPIO21
temperature:
humidity:
model: AM2302
update_interval: 60s
servo:
- id: my_servo
output: pwm_output
# Example output platform
# On ESP32, use ledc output
output:
- platform: ledc
pin: GPIO18
frequency: 50 Hz'
in der configuration.yaml am HA:
'# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
input_number:
servo_control:
initial: 0
min: -100
max: 100
step: 1
mode: slider'
und in der automations.yaml:
'automation:
- alias: Write Servo Value to ESP
platform: state
entity_id: input_number.servo_control
- service: esphome.little_wemos_control_servo
data_template:
level: '{{ trigger.to_state.state | int }}''
