Is there a way to set a global variable with the help of fibaro component?
Greetings!
Greetings!
Not yet I’ll look into it though and see what can be done.
OK - Thank you for your excellent work!
@Peter_Balogh Hi Peter! Any news on global variable integration in the Fibaro component? Read/Write?
Hey, it can be achieved via REST commands. Check this - Curl command to update variable on Fibaro HC3 - #3 by D3v1ld0cs.
